08-26-2011, 03:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | 2 nexus phone both resurrection ok but not turning on? Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.26, JTAG Manager Version: 1.35 Selected Resurrector: [HTC Nexus] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! |
08-26-2011, 13:19 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | riff just repair boot,spl,radio zone and etc but after ressurect you need flash with correct rom remove battry and back,,,hold both vol key and connect usb cable and you see downloading mode....try flash |
08-26-2011, 23:12 | #3 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | Hi thanks for reply my problem is i can not put in download mode i try connect phone with computer dose not work that my problem if i can able to connect phone i can flash but can not connect only i can connect phone when i do ressurect |
08-29-2011, 18:08 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | Brother ,its not software problem,its the flex problem with on/off switch. its the common problem in nexus one.hope u solve the problem. sajidmirza. |
