12-10-2014, 19:11 | #2 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1855858 Status: Offline Thanks Meter: 0 | example : Device : GT-i8190 ; riff LOG ========================== Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. =============================== all pinouts are grounded ( short circuit ) change TCK values and the same |
12-10-2014, 22:06 | #3 (permalink) |
Freak Poster Join Date: Nov 2007 Location: SUKATANI-BEKASI-APAC_X
Member: 624037 Status: Offline Sonork: 100.1608764 Thanks Meter: 41 | Are you before conecting the phone using ATF?, I have one, fuLl shorting, after reading the phone using ATF w/o adafter.because if using adafter the phone not conected. Sent from my BlackBerry 9220 using Tapatalk |
12-11-2014, 18:34 | #4 (permalink) |
Member: 1855858 Status: Offline Thanks Meter: 0 | ATF ( Advanced turbo flasher ? ) ... i have one broken ATF ,,, i think it's installed on my PC ,,, does it make a conflict with riff driver or something so ? waiting for an answer from Blang |
12-11-2014, 22:18 | #5 (permalink) |
Member: 624037 Status: Offline Sonork: 100.1608764 Thanks Meter: 41 | Yes Advance *****, I don't know how it happen, but after try to read the phone, my buzzer of powersuply is ringing, its signing if the phone is shorted, Sent from my BlackBerry 9220 using Tapatalk |
12-11-2014, 22:20 | #6 (permalink) |
Member: 624037 Status: Offline Sonork: 100.1608764 Thanks Meter: 41 | I think about driver is not influence, if the both of box is still conected normaly. Sent from my BlackBerry 9220 using Tapatalk |
