06-06-2014, 12:52 | #1 (permalink) |
Insane Poster Join Date: May 2003 Location: Troisdorf, Germany Age: 41
Member: 29086 Status: Offline Thanks Meter: 5 | Asus Padfone A68 after Ressurection no Power Asus Padfone after Ressurection no download mode or power. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [ASUS Padfone A68 V1.0.5019.4304] Connecting to the dead body...OK Detected dead body ID: 0x107190E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HCG8E, 0x000E90000000 Bytes = 58.25 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HCG8E, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 58,25GB Flashing the dead body...OK Resurrection complete! ID is ignored why the Riff say iss not the right id. |
06-07-2014, 13:33 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi First you must check phone history.if phone died in normal use,it's HW (usually eMMC) if phone died when flashing,try find dump or another alive phone for read dump -- About ID,if you have error about not supporting ID it's normal because possible any revision pcb have a different ID,anyway ID is not problem because You can Ignore it from Advanced Setting like your log |
