03-15-2014, 20:10 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2023556 Status: Offline Thanks Meter: 1 | <B>Need Help With i337 Repair</b> |
03-16-2014, 18:46 | #3 (permalink) |
Member: 2023556 Status: Offline Thanks Meter: 1 | Thank you for the response! my next question is i see that in the video a binary file is being used but the only file provided in the samsung fullflash torrent was a .riffpbin file. and when i try to load in on the dcc write page i cant |
03-16-2014, 20:20 | #5 (permalink) |
Member: 2023556 Status: Offline Thanks Meter: 1 | When I try to read the memory under the dcc read/write tab, I get this: Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G94, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G94, 0x000000400000 Bytes = 4.00 MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Reading MCU address space from 0x000000000000 to 0x0000FFFFFFFF Failed to receive answer to READ command. Any ideas what this could be? I have been getting a lot of no response from riff box errors. i dont think my leads are too long, maybe 5" long. |
03-18-2014, 19:31 | #8 (permalink) |
Member: 2023556 Status: Offline Thanks Meter: 1 | THANK YOU! I have managed to get it up and running in download mode, but when I try to flash in odin, it flashes all the way to the end and then i get secure check fail : system! not sure what this means. I'm not sure which firmware was on the device prior to all the problems |
