Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 09-02-2018, 13:23   #1 (permalink)
Member: 2048673
Thanks Meter: 62
Thumbs down Boot-Lg d855
via USB LG_855 with Riff box loading the Boot phone does not work we are a big problem with Medusa box loading Boot and phone It works properly The Boot Works properly but with Riff box the Boot does not work. a courtesy if you can fix this problem with the Boot via
USB of the LG d855 Thanks
Old 09-02-2018, 15:38   #2 (permalink)
Member: 2048673
Thanks Meter: 62
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.81
Selected Resurrector: [LG D855 USB V1.0.6814.11362]
Connecting to the Device via USB Interface...OK
Initializing Communication via Qualcomm Streaming Download Protocol...OK
Detected eMMC Chip, ID: 0x45/0x01 (SDW16G), User Area Partition = 0x0003AB400000 Bytes (14.68 GB)
No Resurrection Data is available for the eMMC Chip with Capacity = 14,68 GB
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7,28 GB
Flashing the dead body...OK
Resurrection complete!
LG d855 does not work with Riff box that we solve the problem of the Boot with Riff box with Medusa box is the Boot Works properly there is no problem that we only give the problem with Boot thanks We are waiting for a new update
Old 09-02-2018, 16:39   #3 (permalink)
Member: 1868823
Thanks Meter: 47
maybe the resurector file is corupt
Old 09-02-2018, 17:42   #4 (permalink)
Member: 2048673
Thanks Meter: 62
maybe the resurector file is corupt,
SI SI SI SI SI,
Old 09-03-2018, 11:01   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Connect phone, open eMMC Plugin, click "Parse connected eMMC".
Click "Adjust GPT for current chip".
That should recalculate GPT checksums and userdata partition size.
You can also simply write KDZ firmware after extract. (Extract with LG Firmware extractor, and in eMMC plugin click "Parse official firmware". Select "PrimaryGPT.bin" and then simply click flash selected.
Old 09-03-2018, 14:19   #6 (permalink)
Member: 2048673
Thanks Meter: 62
Old 09-03-2018, 16:55   #7 (permalink)
legija's Avatar
Member: 256342
Sonork: None
You have different chip size then one from DLL.
Can You please tell exactly what doesn't work ?
Old 09-03-2018, 18:14   #8 (permalink)
Member: 2048673
Thanks Meter: 62
after loaded the Boot via Pound heads and phone I stay still does not turn on and stay Pound 9008 text I have loaded everything correctly but phone does not enter mode. keeping high volume key by putting the USB cable put the iPhone always remains Pound head
Old 09-03-2018, 18:19   #9 (permalink)
Member: 2048673
Thanks Meter: 62
[QUOTE=legija;13299050]You have different chip size then one from DLL.
downloaded the Boot normally and phone works by entering Recovery mode to load phone software but the problem is phone and always stay Test Point mode never enters Recovery mode that this is the Qualcomm HS-USB problem QDLoader 9008
Old 09-03-2018, 18:22   #10 (permalink)
Member: 2048673
Thanks Meter: 62
I loaded the phone boot properly but the phone remains this Qualcomm HS-USB problem QDLoader 9008 mode
Old 09-03-2018, 22:10   #11 (permalink)
Member: 2048673
Thanks Meter: 62
I downloaded Annovi Boot to Annvoi. dll. file, same problem did not change anything and phone stay with port 9008 never enter mode.Boot,
Qualcomm HS-USB problem QDLoader 9008 mode,
Selected Resurrector: [LG D855 USB V1.0.6820.4413]
Uploading the USB Loader into Device Memory...OK
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 29,12 GB
Old 09-05-2018, 17:48   #12 (permalink)
Member: 356192
Thanks Meter: 8
Hey everyone i need to know something i got old riff box its no more work , should i buy new box or there is any solution i mean activation ? And how much it can be
Old 09-05-2018, 18:39   #13 (permalink)
Member: 2048673
Thanks Meter: 62
https://gsmserver.com/item/credits-a...rt-activation/
https://gsmserver.com/item/credits-a...ag-activation/
Old 09-06-2018, 17:51   #14 (permalink)
Member: 356192
Thanks Meter: 8
Sir one more thing since 2016 i never use this box. Also have to get Support activation as well or only emmc please explain properly
Old 09-11-2018, 03:31   #15 (permalink)
Member: 2048673
Thanks Meter: 62
Page generated in 0.26201 seconds with 8 queries
