02-08-2015, 16:21 | #1 (permalink) |
Registered User Join Date: Apr 2014 Location: Internet
Member: 2171179 Status: Offline Thanks Meter: 35 | C6903 boot dead ------------------------------------- Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 51F69003 HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... PROCEDURE STOPPED BY USER Elapsed:390 secs. -------------------------------------------- Riff team please add model for jtag please help me phone is dead |
02-08-2015, 19:30 | #2 (permalink) |
Member: 2171179 Status: Offline Thanks Meter: 35 | Welcome to S1 tool That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 51F69003 HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... PROCEDURE STOPPED BY USER Elapsed:390 secs. --------------- |
02-08-2015, 23:29 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi This model is C6902 Actually With MSM8274 and S1Tools "NOT SUPPORTED " This ID Also All Variant C6902/03 With MSM8x74 have Pre-disabled JTAG Access |
02-09-2015, 08:31 | #4 (permalink) |
Member: 2171179 Status: Offline Thanks Meter: 35 | ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 DEVICE ID: 0390F651 FLASH ID: "0000/00000000" LOADER VERSION: "LOADER_RELEASE_MSM8974_28_AID_4" PHONE IMEI : 35809405586337 MODEL (from GDFS): C6903 SOFTWARE VERSION: 1272-6084_14.4.A.0.108 CUSTOM VERSION: 1277-2880_R5C FILESYSTEM VERSION: GLOBAL-LTE_14.4.A.0.108 SERIAL NO: BH907XUJ0G phone is c6903 and worked with 3 firmware flash the phone phone imei null and unknown baseband than write gdfs phone is dead please help me have solution for phone ???? change emmc ?? |
