12-05-2012, 22:18 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | ok... flashed now the firmware dump from S5830i (found by riff torrent tracker) and phone gose to download mode again... the fullflash was broken somewhere at 23%, but it was enugh to have working bootloader in the phone.. now it gets detected by odin again... but i cant flash S5839i just like before.. now i try S5830 firmware... anyway... i am happy it is back to download mode... |
12-06-2012, 01:23 | #8 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | phone is back to work fully... @all you can just repair it with the S5830 dump (dont care if is breaks at 23%) after that phone can enter download mode... now you can repair it with S5830i or S5839i flashfiles... but dont use onetime package, as they all dont worked in my phone... now root it and repair imei... i flashed first the phone to S5830i and it is working perfecly with that firmware and for test i flashed back to S5839i firmware and it is also fully working... i forgot to make a dump file from S5839i in working state, but if i have time and if someone needs it, i upload it. |
The Following 2 Users Say Thank You to oOXTCOo For This Useful Post: |
12-07-2012, 12:08 | #11 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | i had also many problems with communications... RTCK signal not found, even i soldered this wire again and again... sometimes it worked but mostly not... just use fixed RCK of 12 mhz! maybe you have same problem with yours... |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
12-07-2012, 21:25 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi @ oOXTCOo Yes,Read full dump is very good idea...so,if you have free time,,plz read and upload,Then give me link for add to RIFF_Tracker.org for help other users.. --- About Connection.... For Some Case USB cable is needed,but for some case needed hold power on key... Also 4MHZ at TCK is Very stable for BCM21xx |
01-28-2013, 01:45 | #14 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Poland
Member: 360641 Status: Offline Thanks Meter: 38 | Dump from s5839i read as s5830i - 4mhz s5839i read by working phone.rar - Speedy Share - upload your files here |
01-28-2013, 02:17 | #15 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
This is worked dump...?Readed After flash with S5839i Firmware or SS5830i Firmware? Can you Take Clear Photo From PCB Pinout? or this model have exactly same by S5830 or s5830i? Also Plz Post full log(I Need Log For See Phone ID) Thanks | |
