03-28-2013, 08:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Proud 2b Pinoy
Member: 534932 Status: Offline Thanks Meter: 49 | Connecting to the Updates Server...ERROR Connecting to the Updates Server...ERROR ERROR: Couldn't connect to the Updates Server. Try again later. please explain Team.. I already disable my antivirus and my net connection is good.. |
03-28-2013, 09:49 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, You don't need to disable AV, it's better to add RIFF directory to exception list to both AV and Firewall. Kaspersky for example, even if it's disabled, it wont let You download anything. But if You add RIFF exe and install directory to exception list, it will work. |
03-28-2013, 11:12 | #3 (permalink) | |
Member: 534932 Status: Offline Thanks Meter: 49 | Quote:
even in no AV PC not work.. i also try your sugestion not work sir.. please guide me.. | |
03-28-2013, 11:34 | #4 (permalink) |
Member: 534932 Status: Offline Thanks Meter: 49 | I tried in no Anti virus installed in PC and newly Format PC and also firewall is off.. same problem : Connecting to the Updates Server...ERROR ERROR: Couldn't connect to the Updates Server. Try again later. I think the Problem is in the server? please kindly check.. Team.. |
03-28-2013, 13:14 | #5 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | No, problem is not with server, server is working fine. Maybe there is some problem with Your ISP, in case that FTP traffic is blocked. Please try to open riff home page (RIFF JTAG Box home page) and let me know if it works or not. |
03-29-2013, 05:05 | #6 (permalink) |
Member: 534932 Status: Offline Thanks Meter: 49 | Hi , The home page are working will.. sir help me! I want to download resurection file to samsung E160l , I can't repair this dead boot phone... please help me, i cant log in the server.. |
04-19-2013, 02:29 | #10 (permalink) |
Junior Member Join Date: Feb 2010 Location: bc canada
Member: 1228914 Status: Offline Thanks Meter: 0 | same problem as mine. i disable antivirus software. same. [2013-4-18 17:41:31] [START OPERATION_ID = GET_INFO] [2013-4-18 17:41:32] Open serial port...OK [2013-4-18 17:41:32] Connecting to the RIFF Box...OK [2013-4-18 17:41:32] [2013-4-18 17:41:32] Getting RIFF Box Info...OK [2013-4-18 17:41:32] RIFF Box S/N: FF.D3DA:BE30-2674:7C92 [2013-4-18 17:41:32] RIFF Box Firmware Version: 1.34 [2013-4-18 17:41:32] [FINISH OPERATION_ID = GET_INFO] [2013-4-18 17:41:36] [START OPERATION_ID = CHECK_UPDATES] [2013-4-18 17:41:57] Connecting to the Updates Server...ERROR [2013-4-18 17:41:57] ERROR: Couldn't connect to the Updates Server. Try again later. [2013-4-18 17:41:57] [FINISH OPERATION_ID = CHECK_UPDATES] [2013-4-18 17:43:45] ------------------------------- JTAG Manager Session Closed ------------ |
08-28-2013, 11:21 | #12 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1395506 Status: Offline Thanks Meter: 6 | Open serial port...OK Connecting to the RIFF Box...OK Getting RIFF Box Info...OK RIFF Box S/N: FF.xxxx:xxxx-xxxx:xxxx RIFF Box Firmware Version: 1.32 Connecting to the Updates Server...ERROR ERROR: Couldn't connect to the Updates Server. Try again later. plz we need solution plzzzzzzzz sir |
