10-09-2013, 15:46 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Poland ,Kraków Age: 46
Member: 117016 Status: Offline Thanks Meter: 2 | desire c problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] WARNING: Reset Override to: [RESET, Wait 40 ms, HALT at 0] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. im check 3 times soldering , etc. whats the next step B.R Rafal |
10-10-2013, 10:01 | #4 (permalink) |
Member: 117016 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
10-10-2013, 10:14 | #5 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Ok, here is list of reasons why this could happen: 1. Dead eMMC chip 2. Bad connection of NRST line 3. Bad connection of GND line 4. Gremlins Can You please elaborate a bit phone history and whats the condition of it now ? |
10-10-2013, 11:38 | #6 (permalink) |
Member: 117016 Status: Offline Thanks Meter: 2 | on usb is show as qd-loader 9008 My client says that : phone have unloced boot and custom recovery this problem was after insert mmc card and reboot phone. other history not known nrst and gnd chack many times Last edited by rafalkapalka; 10-10-2013 at 11:46. |
10-10-2013, 11:56 | #8 (permalink) |
Member: 117016 Status: Offline Thanks Meter: 2 | and without connected usb with external power 4,5 v is that Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x646F ( Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000005000200 |
10-10-2013, 12:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | Hello Riff Team i have repair desire c after repair witch rom i flash? i also change cid to 1111111 ? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC Desire C (PL0110000) V1.0.4807.61567] Connecting to the dead body...OK Detected dead body ID: 0x106010E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (M00SJS, 0x000091000000 Bytes = 2.27 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (M00SJS, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Resurrection complete! |
10-11-2013, 08:15 | #12 (permalink) | |
Member: 129486 Status: Offline Thanks Meter: 66 | Quote:
......... also not write rom. ---------------------------------------------- ROM INFORMATIONS ---------------------------------------------- modelid: PL0110000 cidnum: 11111111 mainver: 1.00.000.0 hbootpreupdate:12 DelCache:1 Checking Device State... FastBoot mode Changing Device state into RUU Mode Rebooting Device Done Preparing Flash operation... Checking Device battery < WAITING FOR DEVICE > BATTERY-STATUS: GOOD MID: PL0110000 VERSION-BOOTLOADER: 1.25.0000 VERSION-MAIN: 1.00.000.0 CID: 11111111 Erasing cache partition... File name: boot.zip Please Wait... sending 'zip' (2385 KB)... Done writing 'zip'... signature checking... FAILED (remote: 12 signature verify fail) Elapsed: 9 seconds | |
10-11-2013, 11:06 | #15 (permalink) |
Member: 129486 Status: Offline Thanks Meter: 66 | Hello i have also write with this rom RUU_GOLF_U_ICS_40A_hTC_Asia_WWE_2.00.707.1_Radio_1 0.16.98.09_1.10.98.15_release_297993_signed says Error (132): SIGNARURE ERROR |
