07-31-2012, 11:38 | #1 (permalink) | |||
Insane Poster Join Date: Feb 2012
Member: 1720265 Status: Offline Thanks Meter: 2 | Desire HD HELL i will randomly get different errors such as below, i just dont know what to do, i read in the ressurection manual that the jtag may be disabled i am really hoping that that isnt the case i even tried the USB DLL Quote:
07-31-2012, 17:47 | #3 (permalink) |
Crazy Poster Join Date: Oct 2011
Member: 1670612 Status: Offline Thanks Meter: 5 | Hi Folks, I am trying to resurrect a Desire HD and I am having the same erros above, everytime I got one different error like: ERROR(0x44): Communication is not established. Terminating and also: ERROR: Read/Write memory failed during H/W Init. and: ERROR: Wrong response code from the RIFF Box: 0x4E. If I try by USB mode I can not go trough because the computer give me Unknow Device most of time and i can setup the USB driver for it, when I go little further it counts up to 5 and nothing happened. In fact I have a JTAG adapter , it detects the correct dead body but I can not go further. Do you think I will get better results if I sold the wires on it? I am thinking because I ever could fix one Desire HD by this method using JTAG adapter. I also did not understand how to use TP with Riff Box fixing the Desire HD. Any help will be very appreciated, thank you very much again. |
07-31-2012, 20:03 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi if you have a same or any problem,Please open own thread ---- Anyway... 0X44 it's mean FSBl loader damaged and you need repair phone via USB.dll version -------------------------------- TP instructaion is easy.. connect power supply into phone .... connect usb cable into phone(but not coonect to pc) connect and keep TP.....(connect tp point to GND) put USB cable to PC...,Then release TP --------------------------- |
08-01-2012, 07:13 | #5 (permalink) |
Member: 1670612 Status: Offline Thanks Meter: 5 | Thank you for your help my dear friend. Next time I will open a new post. I still have some questions: I usually provide power from the Riff Box and USB cable, shall i use external power supply and usb cable? How about to try solder wires on the Desire HD process? Since I ever got this model working correctly with the JTAG adapter, I am thinking of it. Thanks again, |
08-01-2012, 22:24 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I never use jig adapter because solder wire is very easy for me.....and it's a secure and safe --- You Can use battery,but power supply is easy to use -- for solder pinout,you need check photo inside in dll-(interface pinout) |
08-04-2012, 06:49 | #7 (permalink) |
Member: 1670612 Status: Offline Thanks Meter: 5 | Thanks again. I already did some devices with the solder pinout (n7000, i9000, i9100, i5500, etc), just the ones which I do not have JTAG/JIG Adapter, some worked fine, others did not, in fact I am not very handy with the wire solder but I have on friend who does it for me and he does a great job, always 100%, that's I am talking about, because sometimes with the jig I can not make it. Also with the wires soldered we use the power supply that comes from Riff Box and worked 100% of times, with JTAG/Jig, seems to not work all the time. Anyway, I will analise what to do from now on, I will try the JTAG/Jig first and if does not work I will go for wires soldered. |
c25 v07- what the hell?!?! | monol | x1x to x45/x50 | 2 | 02-19-2002 23:32 |
Restore the original IMEI on HD-1 | tati | Alcatel & TCL Old Models | 6 | 09-22-2001 00:27 |
HEEEELP!!! Destroyed one OTE HD-1 v15 | mashco | Alcatel & TCL Old Models | 0 | 05-25-2000 21:14 |
hd-5 .abs files | sancio | Alcatel & TCL Old Models | 0 | 11-13-1999 01:33 |
Alcatel OneTouch Club+, I need sign... HD? | Liquid | Alcatel & TCL Old Models | 1 | 07-28-1999 02:04 |
