05-04-2013, 02:33 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 656666 Status: Offline Thanks Meter: 28 | Desire HD Help new user Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC Desire HD V1.0.4727.5782] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. what I do wrong? [5/3/2013 9:27:07 PM] [START OPERATION_ID = RESURRECT] [5/3/2013 9:28:24 PM] Open serial port...OK [5/3/2013 9:28:24 PM] Connecting to the RIFF Box...OK [5/3/2013 9:28:24 PM] Firmware Version: 1.35, JTAG Manager Version: 1.49 [5/3/2013 9:28:24 PM] Selected Resurrector: [HTC Desire HD V1.0.4727.5782] [5/3/2013 9:28:24 PM] [5/3/2013 9:28:24 PM] Connecting to the dead body...OK [5/3/2013 9:28:24 PM] Detected dead body ID: 0x17B360E1 - CORRECT! [5/3/2013 9:28:24 PM] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [5/3/2013 9:28:24 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [5/3/2013 9:28:24 PM] [5/3/2013 9:28:24 PM] Resurrection sequence started. [5/3/2013 9:28:24 PM] Establish communication with the phone...FAILED [5/3/2013 9:28:24 PM] ERROR(0x44): Communication is not established. Terminating. [5/3/2013 9:28:24 PM] [FINISH OPERATION_ID = RESURRECT] [5/3/2013 9:28:40 PM] [START OPERATION_ID = JTAG_ANALIZE] [5/3/2013 9:28:40 PM] Open serial port...OK [5/3/2013 9:28:40 PM] Connecting to the RIFF Box...OK [5/3/2013 9:28:40 PM] Firmware Version: 1.35, JTAG Manager Version: 1.49 [5/3/2013 9:28:40 PM] Selected Resurrector: [HTC Desire HD V1.0.4727.5782] [5/3/2013 9:28:40 PM] [5/3/2013 9:28:40 PM] Connecting to the target...OK [5/3/2013 9:28:40 PM] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [5/3/2013 9:28:40 PM] [5/3/2013 9:28:40 PM] Following devices are found on the JTAG chain: [5/3/2013 9:28:40 PM] Device on TAP #0: ID = 0x17B360E1, IR Length = 0x05 bits [5/3/2013 9:28:40 PM] Total IR length: 0x0005 bits [5/3/2013 9:28:40 PM] [5/3/2013 9:28:40 PM] Analizing IDCODE(s) of the JTAG scan chain: [5/3/2013 9:28:40 PM] 1. 0x17B360E1: Qualcomm MSM8255, H/W Rev. #1 [5/3/2013 9:28:40 PM] 2. 0x17B360E1: Qualcomm MSM8255T, H/W Rev. #1 [5/3/2013 9:28:40 PM] 3. 0x17B360E1: Qualcomm MDM6600, H/W Rev. #1 [5/3/2013 9:28:40 PM] [FINISH OPERATION_ID = JTAG_ANALIZE] [5/3/2013 9:28:41 PM] [START OPERATION_ID = GET_DEVICE_ID] [5/3/2013 9:28:41 PM] Open serial port...OK [5/3/2013 9:28:41 PM] Connecting to the RIFF Box...OK [5/3/2013 9:28:41 PM] Firmware Version: 1.35, JTAG Manager Version: 1.49 [5/3/2013 9:28:41 PM] Selected Resurrector: [HTC Desire HD V1.0.4727.5782] [5/3/2013 9:28:41 PM] [5/3/2013 9:28:41 PM] Connecting to the dead body...OK [5/3/2013 9:28:41 PM] Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK [5/3/2013 9:28:41 PM] [5/3/2013 9:28:41 PM] Detected dead body ID: 0x17B360E1 [5/3/2013 9:28:41 PM] [FINISH OPERATION_ID = GET_DEVICE_ID] |
05-04-2013, 07:10 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi 0X44 error Mean Damaged FSBL Loader.... So FSBL Can Damaged By 2 Reason Damaged Chip(HW Problem) Damaged SW By Wrong Firmware --- 1-For First Try,You need use USB.dll version 2-if usb.dll can't repair,You need replace eMMC |
05-04-2013, 17:26 | #4 (permalink) |
Member: 656666 Status: Offline Thanks Meter: 28 | I fixed driver issue had to turn off signature verification but now stuck here device reboots to unkown under device manager and riff box just stays here stuck .. One last thing do I need to have jjag wires connected to run if in usb mode? |
05-04-2013, 19:49 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi.. No,no need solder jtag wires -- You Must Use TP..... if PC Say "Unknown Device" After Press Resurrect,It's Mean You Have Bad TP.... So,Just Try Again But if PC Can Detect "QUHSB_xxxxxx" Without TP,Usually Mean eMMC Damaged |
