01-06-2015, 22:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Algeria
Member: 756942 Status: Offline Thanks Meter: 81 | Dll for tablet Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz Detected dead body ID: 0x007700E1 ----------------------------------------------------------------------------------------------- 1- Analyze jtag chain Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is 5 kHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x007700E1, IR Length = 0x04 bits Total IR length: 0x0004 bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x007700E1: Qualcomm MSM8225, H/W Rev. #0 ----------------------------------------------------------------------------------------------- read memory Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz Settings Code: 0x00010100000000000000000080000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. ---------------------------------------------------------------------------------------------------------------------------- read memory Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz Settings Code: 0x00010100000000000000000080000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: No response from the RIFF Box. ---------------------------------------------------------------------------------------------------------------------------- read memory Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz Settings Code: 0x00010100000000000000000080000000 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. ---------------------------------------------------------------------------------------------------------------------------- Last edited by BOOTB; 01-06-2015 at 22:09. |
01-07-2015, 00:07 | #3 (permalink) |
Member: 756942 Status: Offline Thanks Meter: 81 | with RTCK Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...ERROR ERROR: The RTCK Signal does not respond. ------------------------------------------------------------------------------------- With 1MHZ Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8825D V1.0.4710.49481] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 1 MHz Settings Code: 0x00010600000000000000000080000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. --------------------------------------------------------------------------------------------- About cpu 0x007700E1: Qualcomm MSM8225 My tablet is work very fine |
