04-23-2012, 17:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | E15i dead whenn try resurect ? mobile is working, i check it before unlock. then conect to RIFFBOX and test comunication with JTAG READ/WRITE: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.42 Selected Resurrector: [SE E15i V1.0.4463.41118] Connecting to the dead body...OK Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Detected dead body ID: 0x203C00E1 then try to Resurect it: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.42 Selected Resurrector: [SE E15i V1.0.4463.41118] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x45): Communication is not established. Terminating. after that unable to connect to device. every time get this error: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.42 Selected Resurrector: [SE E15i V1.0.4463.41118] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x45): Communication is not established. Terminating. i check cables 3-4 times. resolder wires. but again this error. now mobile start and after vibration stop in begining oonly backlight on device. nothig more on LCD. what is the problem and how to fix it ? help quickly guys, 10x. |
04-23-2012, 18:22 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | As i can see, You never actually managed to connect it. Plus - from log I can see there was problem with NRST (0x45). Most probably You shorted some pins on board. |
The Following User Says Thank You to legija For This Useful Post: |
04-24-2012, 07:17 | #3 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | this is LOG of operations from beginning for this device: [23.4.2012 г/ 16:25:55] ------------------------------- JTAG Manager Session Opened ------------------------------- [23.4.2012 г/ 16:25:55] JTAG Manger Version: 1.41 [23.4.2012 г/ 16:25:55] ------------------------------------------------------------------------------------------- [23.4.2012 г/ 16:37:09] [START OPERATION_ID = GET_DEVICE_ID] [23.4.2012 г/ 16:37:10] Open serial port...OK [23.4.2012 г/ 16:37:10] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:37:10] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:37:10] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:37:10] [23.4.2012 г/ 16:37:10] Connecting to the dead body...OK [23.4.2012 г/ 16:37:10] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [23.4.2012 г/ 16:37:10] Model selected: SE - SE E15i [23.4.2012 г/ 16:37:10] [23.4.2012 г/ 16:37:10] Detected dead body ID: 0x203C00E1 [23.4.2012 г/ 16:37:10] [FINISH OPERATION_ID = GET_DEVICE_ID] [23.4.2012 г/ 16:37:15] [START OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:37:30] Open serial port...OK [23.4.2012 г/ 16:37:30] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:37:30] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:37:30] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:37:30] [23.4.2012 г/ 16:37:30] Connecting to the dead body...OK [23.4.2012 г/ 16:37:30] Detected dead body ID: 0x203C00E1 - CORRECT! [23.4.2012 г/ 16:37:30] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [23.4.2012 г/ 16:37:30] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [23.4.2012 г/ 16:37:30] [23.4.2012 г/ 16:37:30] Resurrection sequence started. [23.4.2012 г/ 16:37:30] Establish communication with the phone...FAILED [23.4.2012 г/ 16:37:30] ERROR: No response from the RIFF Box. [23.4.2012 г/ 16:37:30] [FINISH OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:37:34] [START OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:37:35] Open serial port...OK [23.4.2012 г/ 16:37:35] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:37:35] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:37:35] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:37:35] [23.4.2012 г/ 16:37:35] Connecting to the dead body...ERROR [23.4.2012 г/ 16:37:35] ERROR: The RTCK Signal does not respond. [23.4.2012 г/ 16:37:35] [FINISH OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:37:38] [START OPERATION_ID = GET_DEVICE_ID] [23.4.2012 г/ 16:37:39] Open serial port...OK [23.4.2012 г/ 16:37:39] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:37:39] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:37:39] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:37:39] [23.4.2012 г/ 16:37:39] Connecting to the dead body...ERROR [23.4.2012 г/ 16:37:39] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [23.4.2012 г/ 16:37:39] Model selected: SE - SE E15i [23.4.2012 г/ 16:37:39] [23.4.2012 г/ 16:37:39] ERROR: The RTCK Signal does not respond. [23.4.2012 г/ 16:37:39] [FINISH OPERATION_ID = GET_DEVICE_ID] [23.4.2012 г/ 16:37:46] [START OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:37:56] Open serial port...OK [23.4.2012 г/ 16:37:56] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:37:56] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:37:56] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:37:56] [23.4.2012 г/ 16:37:56] Connecting to the dead body...OK [23.4.2012 г/ 16:37:56] Detected dead body ID: 0x203C00E1 - CORRECT! [23.4.2012 г/ 16:37:56] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [23.4.2012 г/ 16:37:56] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [23.4.2012 г/ 16:37:56] [23.4.2012 г/ 16:37:56] Resurrection sequence started. [23.4.2012 г/ 16:37:56] Establish communication with the phone...FAILED [23.4.2012 г/ 16:37:56] ERROR: No response from the RIFF Box. [23.4.2012 г/ 16:37:56] [FINISH OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:38:07] [START OPERATION_ID = RESURRECT] [23.4.2012 г/ 16:38:15] Open serial port...OK [23.4.2012 г/ 16:38:15] Connecting to the RIFF Box...OK [23.4.2012 г/ 16:38:15] Firmware Version: 1.31, JTAG Manager Version: 1.41 [23.4.2012 г/ 16:38:15] Selected Resurrector: [SE E15i V1.0.4463.41118] [23.4.2012 г/ 16:38:15] [23.4.2012 г/ 16:38:15] Connecting to the dead body...OK [23.4.2012 г/ 16:38:15] Detected dead body ID: 0x203C00E1 - CORRECT! [23.4.2012 г/ 16:38:15] Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK [23.4.2012 г/ 16:38:15] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [23.4.2012 г/ 16:38:15] [23.4.2012 г/ 16:38:15] Resurrection sequence started. [23.4.2012 г/ 16:38:15] Establish communication with the phone...FAILED [23.4.2012 г/ 16:38:15] ERROR(0x42): Communication is not established. Terminating. [23.4.2012 г/ 16:38:15] [FINISH OPERATION_ID = RESURRECT] ..... any idea whoat to do ? |
04-24-2012, 08:29 | #4 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | mobile is ready and working. strange, but RIFFBOX kill this device. this is my first killed mobile with this JTAG. Now I use again RIFFBOX with other device and work good. after reflash with setool this E15i start normally. Last edited by Svetli; 04-24-2012 at 08:30. Reason: [SOLVED] |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
try this for nokia 5.36 | BELY | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-28-2000 00:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
