Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 05-04-2012, 03:08   #1 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
eMMC Infos
hi all
this is some information about eMMC for some phone for users who have problems with it .
when you have eMMC chip error on Resurrection that's mean it's dead or not detected and not riffbox fault . it's hardware problem .
eMMC
eMMC describes an architecture consisting of an embedded storage solution with MMC interface, flash memory and controller, all in a small ball grid array (BGA) package.
Embedded MultiMediaCard (e-MMC) e-MMC/Card Product Standard, High Capacity, including Reliable Write, Boot, Sleep Modes, Dual Data Rate, Multiple Partitions Supports and Security Enhancement.
16-Gbyte flash complies with eMMC standard
The THGAM0Gxxxx series of embedded NAND flash memory chips complies with the MultiMediaCard Association (eMMC) interface standard. The devices provide 1 to 16 Gbytes in a single package, and their MMC Version 4.2 controller handles block management, error correction, and driver software.
The FBGA169-packaged 16-Gbyte device combines eight 2-Gbyte chips, fabricated using a 56-nm process, and a controller chip. The devices write at 6 Mbytes/s and read at 15 Mbytes/s. (8-Gbyte model, $155 ea/sample qty—samples available now for 8 Gbytes, June for 16 Gbytes, others 4th qtr.)
Today's fastest and most demanding embedded applications, such as multi-functional smartphones,
PMPs, and tablet computers, require equally capable memory management solutions to provide a rich end-user experience.
Such devices most commonly employ flash memory for content storage.
Typically, flash memory is controlled by a dedicated controller that supervises data reads and writes, and operates under the control of the application's CPU. However, with developments in semiconductor technologies, memory densities are advancing at rapid rates, resulting in memory chips with ever-increasing capacities and making it difficult to keep the controller off the flash memory die. To maintain the required data rates and throughputs for high-density chips designed to store high-resolution video and provide enhanced storage capabilities, the eMMC standard was developed.
eMMC is a standard for embedded memory devices that contain not only a data storage element (such as NAND flash memory), but also a controller for the storage element integrated on the same silicon die. This results in several advantages, such as reduced development time and easier integration of the memory block in the overall system. Ultimately, this leads to a much shorter time-to-market for the end product.
The eMMC solution consists of three components - the MMC (multimedia card) interface, the flash memory, and the flash memory controller - and is offered in the industry-standard BGA package. The MMC System Specification v4.41 and JEDEC BGA packaging standards together define the finer points of the eMMC solution.
The following illustration shows technology areas where eMMC solutions will excel.
Standard-cell library offerings
With interface speeds of up to 52MB/s, configurable bus widths of x1, x4, or x8, and interface voltages of either 1.8V or 3.3V, eMMC is designed to provide fast, reliable, and scalable performance.
The flexibility of the industry-standard architecture of the eMMC solution means that designs for mass-storage applications (such as external HDDs) for portable consumer electronic products are greatly simplified. The eMMC interface design allows a host system to access all major types of mass-storage memory devices, such as embedded memory (eMMC-based memory itself), SD/MMC memory cards, and HDDs (using the "ATA on MMC" specification, making it easier for devices such as mobile handsets containing MMC technology to use the larger capacities of small form-factor hard drives) with a single common MMC Interface Protocol Bus.
Development stages for regular NAND flash-based product
For a product using NAND memory, any changes in the chipset, operating system (OS), or the NAND memory requires changes to be made in the Flash Translation Layer (FTL), which in turn, requires testing the changes at the NAND level, significantly increasing delays for product level testing.
Compared to this, when eMMC is used, intermediate changes need not be tested, since the MMC interface takes care of everything. The following illustration shows the elegance of this solution.
This design also makes it possible to select suppliers for subcomponents from a wider base, which results in increased revenues with lower times-to-market.
The future for eMMC is moving towards its integration and deployment with a new architecture (presently under development) - eMCP. eMMC eliminates the need to develop interface software for all types of NAND memory by integrating the embedded controller into the memory chip and providing an easy-to-use memory solutions package for high-speed data transmissions by devices, such as mobile phones. It also eliminates the need for a memory expansion slot by stacking several memory functions vertically, resulting in a very small footprint for the memory devices.
The following illustration shows how this stack-up works to increase and improve the memory densities of devices.
moviMCP integration with eMMC
As an example, eMCP can be deployed to store the code for an application in the SLC NAND/NOR and DRAM memory, whereas the data can be stored in the eMMC memory in a device.
The latest mobile devices are expected to contain bootable eMMC modules, allowing the device's operating system to partition and format the memory modules as needed, and then boot the device off the modules. Designs are also moving towards a unified, hybrid architecture (supporting both SLC and MLC memory), as illustrated below.
Migration towards a hybrid architecture for SLC and MLC memory
By adopting eMMC, manufacturers stand to significantly gain from simpler and faster product designs, qualification processes, and a much shorter overall time-to-market.
The next illustration shows the BGA packages that Samsung eMMC memory is available in.
Specifications for Samsung's eMMC chips
Benefits
The key benefits of using Samsung's eMMC memory solutions include:
  • Ease of use :
    Use of the industry-standard eMMC 4.41 interface turns memory accesses into simple read/write operations. Furthermore, the interface eliminates the need to develop separate firmware for the eMMC controller. The interface is flexible and can be configured to operate in either x1, x4 or x8 modes, and runs at either 26MHz or 52MHz.
  • Low-cost :
    eMMC provides a cost-effective solution and lower development times, resulting in a lower overall time-to-market for your product. The ability of eMMC to be used with both SLC- and MLC-type NAND memory makes it ideal for deployment across any segment, including low-cost legacy chipsets. The latest and revised versions of eMMC are expected to be JEDEC compliant, simplifying designs to great extents.
  • Host isolated from changes in NAND memory technology :
    The basic design principle of eMMC makes it possible to let technology changes in NAND memory of the end device remain invisible to the host. This significantly reduces the design, development, and testing time for your product, since the Flash Translation Layer (FTL) no longer exists, and does not need to be changed for any NAND-level changes in your product.
  • Operation on standard voltage levels:
    eMMC memory requires dual power supplies for its operation - a 3.0V (Vcc) for MLC NAND flash, and a 1.8V/3.0V (Vccq) for the controller block. Both these voltage values are standard and available on almost all devices
Applications
The key application areas for Samsung's eMMC memory include:
  • Mobile devices :
    Advanced mobile devices and handsets today contain significant computing power and high-end multimedia features, such as high-definition video playback. A significant amount of space is required to store such content, and technologies like eMMC are excellent solutions for such applications. Additionally, eMMC chips (both SLCs and MLCs) are already being used in mobile devices to provide booting functionality.
  • Enhanced storage solutions :
    Smartphones, tablet PCs, and digital cameras are increasing in their capabilities and are requiring larger density solid state memory that can be easily integrated into system designs. With eMMC, increasing the storage on such devices has become not only simpler, but also cost-effective.
  • Replacement for traditional storage media :
    Recent trends show that HDDs are slowly being phased out and being replaced by SSDs due to their ever-improving benefits, such as increasing storage densities, reducing costs, and lower power consumption, among others. eMMC's high storage capacity makes it the number one contender as a replacement for traditional storage media.
eMMC is the next big step in memory technology, especially for the mobile platform. Samsung's worldwide technology leadership in memory and expertise in the semiconductor segment will ensure that customers remain ahead at every single step of this exciting journey.
The Following 4 Users Say Thank You to allal123 For This Useful Post:
Old 05-04-2012, 05:28   #2 (permalink)
Crazy Poster
Member: 312449
Very Nice information ......now my concept clear...............
THANX
wbr...
Old 05-04-2012, 17:36   #3 (permalink)
Crazy Poster
Member: 419497
Sonork: 100.1615725
Thank you! Very useful information!
Old 08-28-2012, 11:29   #4 (permalink)
Member: 1705542
Thanks for detailed explanation.
Is anybody can suggest reliable eMMC chips supplier for servicing purposes of mobile devices with malfunctioning eMMC ?
Old 08-28-2012, 13:34   #5 (permalink)
Reza2010's Avatar
Member: 1541831
Sonork: 100.1620784
Thanks a lot sir....very good and nice information........
Please send info azza69 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-11-2000 14:19
I need info doc to make scripts for send.exe ThanksĦĦ Bolo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 04-09-2000 11:49
Please info unlock 6150v517 cIVIc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-27-1999 20:11
Please info unlock 6150 v5.17 cIVIc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-01-1999 02:13
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 0.43796 seconds with 8 queries
