12-23-2013, 21:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | It is EMMC problem??? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung M250S V1.0.4990.45084] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.86V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14,68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
12-23-2013, 21:57 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi as i can see,Yes .....But Why you select 100KHZ at TCK Speed? if you get some error when higher speed Please resolder all jtag wires and try with 8MHZ -- Also Please Resurrect with latest I9100.dll (ver 10.48) and post log...(need with 8MHZ) Thanks |
12-23-2013, 22:40 | #3 (permalink) |
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | same problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9100 V1.0.4850.415] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14,68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
12-23-2013, 22:46 | #4 (permalink) |
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | after press power button phone is 60 ma, protsessor medium hot! phone did not fall within the very clean! Last edited by mastersgsm; 12-23-2013 at 22:55. |
01-12-2014, 18:38 | #6 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania Buzau Age: 54
Member: 14468 Status: Offline Thanks Meter: 50 | I have the same error... First this: Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000004000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000008000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000000C000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000010000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000014000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x000000018000 is handled as Cut Excess. WARNING: Programming Error (0x25) at 0x00000001C000 is handled as Cut Excess. and then no emmc... best regards vali |
03-11-2014, 22:23 | #7 (permalink) | ||
Freak Poster Join Date: Feb 2005
Member: 121375 Status: Offline Thanks Meter: 25 | Erase OK: Quote:
