07-17-2018, 08:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 44
Member: 71526 Status: Offline Thanks Meter: 48 | Need HP pro slate 12 GPT HP uses similar partition layout as others, but some of partitions names must be exactly written. CPU is Qcom SD 801. |
07-20-2018, 10:20 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Is there firmware available for download ? There could be GPT within, in worst case You should check end address for user partition for backup GPT. |
07-24-2018, 12:38 | #3 (permalink) | |
Member: 71526 Status: Offline Thanks Meter: 48 | Quote:
Dear Legija , Emmc was compleatly dead, so I have replaced it. Have no dump. HP support has only update.zip. Inside zip I have not found gpt, but found firmware folder, so I've wrote gpt fom lenovo (same CPU) and original firmware partitions from HP. Now device loads recovery, but cannnot do update from zip - it fails due to shortage free space of cash partition. (but there not chash partition size problem). I think that missing some partitions or its names not exactly, because I have found in firmware upgrade procedures that uses "partition by name". and mentioned partitions: Code: modemst1 modemst2 fsg fsc ssd mdm1m9kefs1 mdm1m9kefs2 mdm1m9kefs3 mdm1m9kefsc misc bootselect pad config system recovery userdata oem cache boot aboot modem | |
