05-21-2018, 22:25 | #1 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2709215 Status: Offline Thanks Meter: 0 | ERROR: At least 1.49 Box's Firmware version is required ERROR: At least 1.49 Box's Firmware version is required. Current version is RECOVERY. Please update BOX Firmware. Yet when I run the update, I get the following message: Getting RIFF Box Info...OK RIFF Box Bootcore version 2.00...OK Connecting to the Updates Server...OK Downloading new Firmware from Server...OK Setting Update Mode...OK Updating Box's Firmware...OK Restarting box, please wait...OK Firmware Update Completed OK Current Firmware Version: Recovery (RIFFBOX2) What can be done to correct this so that the box can operated? I am running Win 10 Enterprise (64-bit) |
05-22-2018, 10:05 | #2 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
replug box create Update port ...Recovery firmware will be flashed. br, | |
05-22-2018, 20:10 | #3 (permalink) |
Member: 2709215 Status: Offline Thanks Meter: 0 | Thanks. Although, I am not clear on what you are saying... The RIFF Box is showing up in device manager as USB Service Device (COM9) and if I attempt to update the driver Windows tells me that is already up to date. |
05-22-2018, 21:22 | #4 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Quote:
2. Go Device Manager, 3. Right Click on USB Service Device (COM9) & Select Manually Update Driver I)........Select Brouse for drivers on your computer, II).......Select the device driver you want to install for this hardware. III)......Now here you see RIFF BOX II Firmware Update Driver, just select & Click Next IV)......After Driver Installation successfully see in Device Manager now there RIFF BOX II Firmware Update Port (COM9) show... Like This... 4. Now Open JTAG Manager & Update ur Box again... | |
The Following User Says Thank You to Pijush Das For This Useful Post: |
05-23-2018, 01:12 | #6 (permalink) |
Member: 2709215 Status: Offline Thanks Meter: 0 | After attaching the RIFF Box and stating the JTAG Manager software, it appears to be communicating properly... When looking at Device Manager, the RIFF Box is showing as follows... When I attempt to install the RIFF Box Firmware driver, these are current drivers I have to choose from... Yet, whichever driver I choose I get the message and I am unable to install an updated driver... |
05-24-2018, 18:33 | #8 (permalink) | |
Just install official Driver from installation directory.... I already give u instroduction, just follow & do apply same method... Again say you please Apply this process.... 1. Connect RIFF BOX 2 in PC, 2. Go Device Manager, 3. Right Click on USB Service Device (COM9) & Select Manually Update Driver I)........Select Brouse for drivers on your computer, II).......Select the device driver you want to install for this hardware. III)......Now here you see RIFF BOX II Firmware Update Driver, just select & Click Next IV)......After Driver Installation successfully see in Device Manager now there RIFF BOX II Firmware Update Port (COM9) show... Last edited by Pijush Das; 05-25-2018 at 20:00. | |
