11-15-2012, 12:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 929 | Error Repair E15i Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [SE E15i V1.0.4463.41118] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory access timed out. br, |
11-17-2012, 00:01 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Usually E15i Work only via max speed.. But this is bad connection or lost power So,Please check/resolder all wires connect power supply and USB cable Press "Resurrect" |
11-17-2012, 04:56 | #4 (permalink) |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 929 | jtag solder is ok, usb and power suplay is ok I think this HW problem when i check board is not clear flash ic have rehot with someone Thanks for answer Br, cavella |
