12-20-2013, 15:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: italy
Member: 548901 Status: Offline Sonork: 100.1644756 Thanks Meter: 51 | error resurrection i9505 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9505 V1.0.5067.52246] Connecting to the dead body...OK Detected dead body ID: 0x2071B0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
12-23-2013, 22:01 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi i'm here...sorry for late.. as i can see you have hw problem because "no response xxxx" error usually mean eMMC damaged but can you try this and report? 1-resolder all jtag wires... 2-solder again all wires (double check GND + NRST) 3-connect usb socket to pcb and put only usb cable to phone 4-select 1MHZ at TCK Speed 5-Press "Resurrect -if still you have same problem....try with connect battery without usb by press power key -- also please Read:RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. |
