10-21-2013, 14:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Melbourne Aussy
Member: 192176 Status: Offline Sonork: 100.1646924 Thanks Meter: 35 | Failed to Unbrick HTC One S (PJ4020000) Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [HTC OneS (PJ4020000) V1.0.4926.47132] Connecting to the dead body...OK Detected dead body ID: 0x204210E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. if with jtag chain like this : Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4F1F0F0F, IR Length = 0x04 bits Device on TAP #1: ID = 0x204210E1, IR Length = 0x0B bits Total IR length: 0x000F bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x204210E1: Qualcomm MSM8260, H/W Rev. #2 What is the problem coming from eMMC ic? |
10-21-2013, 14:45 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Error 0x44 means that device cannot be halted. In this case, it's probably due bad or not existing NRST line connection. Can be also caused by bad power. Since booting sequence didn't reached stage where is DCC loader uploaded, it has nothing to do with actual eMMC state. |
10-21-2013, 17:16 | #3 (permalink) |
Member: 192176 Status: Offline Sonork: 100.1646924 Thanks Meter: 35 | I try to change with different cable to jtag pad and cek line all be work,and also change power with psu unit to prevent bad power,but the result always still same. |
10-22-2013, 05:53 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi For Resurrect One-S S3 You need connect only USB Cable Phone Can't Halt With Both Power and USB Or Just Connect Battrey,Press and Keep Power on Then Press Resurrect Thanks |
10-22-2013, 13:33 | #5 (permalink) | |
Member: 192176 Status: Offline Sonork: 100.1646924 Thanks Meter: 35 | Quote:
Detected dead body ID: 0x204210E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. thanks abt advice sir ,I've tried everything including what you have suggest,start with just installing usb as power or by using the battery as the power remains the same but the results can not resolve the problem, I tried to use another jtag box berhasil.what is there a problem with the device we do? or there is a hardware problem that jtag box can not work well | |
