Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 11-23-2012, 11:02   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
Flashing Full Flash S5830
hello all,
I want flash a S5830 with RIFF, and after resrect and want flash I have this error :
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
ERROR: Selected Image file's Size differs from the Autodetected (512MB) FullFlash Size.
any one can help me pls ?
Best Regards,
JAVA Good.
Old 11-23-2012, 19:04   #2 (permalink)
Member: 1749693
Sonork: 100.1618331
Thanks Meter: 15
hi
just choice file size
Old 11-23-2012, 19:04   #3 (permalink)
Member: 1749693
Sonork: 100.1618331
Thanks Meter: 15
hi
Old 03-02-2013, 13:49   #4 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
hello all,
I have this now :
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.34, JTAG Manager Version: 1.45
Selected Resurrector: [Samsung S5830 V1.00]
Connecting to the dead body...OK
Detected dead body ID: 0x303C10E1 - CORRECT!
Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x20010000000000000000000020000000
(512MB)
Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF
ERROR: Timeout while waiting for DCC Loader response. Trying to recover...FAILED
ERROR: Failed due to multiple communication errors. Terminating at 0x0000000C0000FAILED
what is solution ?
Best Regards,
JAVA Good.
Old 03-03-2013, 12:41   #5 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,738
@JAVA Good
erase chip fst do repair boot , and check that after repair boot your able to boot phone in download mode ?if yes then tell me
Old 03-03-2013, 13:14   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,406
Originally Posted by JAVA Good View Post
hello all,
I have this now :
what is solution ?
Best Regards,
JAVA Good.
Hi
Solution Inside Here : RIFF JTAG Box FAQ - ERROR: Failed due to multiple communication errors.
Old 03-03-2013, 13:19   #7 (permalink)
Member: 1719412
Thanks Meter: 11
hi mr. babak
what happend if we use your solution but Do not resolves the issue..???
tnx
Old 03-03-2013, 17:34   #8 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
@ Faheem Anjum
tks, but where is this ERASE FONTION on software pls ?
and after repair boot, most of S5830 don't go to dowload mode, but have blue screen if I'am not wrong, I think need flash it with riff and like some unlocker tell it's take about 1 hour.
@ BABAK NURI
tks but don't work for me.
Best Regards,
JAVA Good.
Old 03-03-2013, 23:58   #9 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,406
Originally Posted by fardis View Post
hi mr. babak
tnx
Hi
This Happen by 2 reason:
1-Bad soldering....,not Powered target,,,not connected USB
2-HW Problem(MCU+Flash Chip)
So,For Better Understand....
Plz Use short wires
use USB or Connect JIG Clip
Use Power Supply
Test With Few Speed on TCK,Like 8MHZ oe 2MHZ
or
Of course Best Way is Contact Me Via Sonork,(For Check Phone Via Remote....
Old 03-03-2013, 23:59   #10 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,406
@ Faheem Anjum
@ BABAK NURI
Best Regards,
JAVA Good.
Hi
For Erase : RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB
For Blue Screen:
You Need Write Full Dump...
You Can Download From here :
Riffbox Server :: Login
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 03-04-2013, 01:08   #11 (permalink)
Member: 1893666
Sonork: 90070
I think nothing can help you sir..
Old 03-05-2013, 08:28   #12 (permalink)
Member: 1719412
Thanks Meter: 11
Originally Posted by BABAK NURI View Post
Hi
Plz Use short wires
Use Power Supply
or
yeah man you right
Old 03-05-2013, 14:37   #13 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
@ BABAK NURI
ok tks,
1) when I eare my phone I have this log :
Detected dead body ID: 0x303C10E1 - IGNORED!
Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz]
Settings Code: 0x0501000A000000000000000020000000
Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK
WARNING: Erasing Error (0x24) at 0x00001FE80000. Attempt to Repeat again.
WARNING: Erasing Error (0x24) at 0x00001FE80000 is Ignored. Erase continues.
Completed in 00:00:18.391 (Average Transfer Rate: 28507.86 kB/s)
the yellow line is normal ?
2) after erase the phone, I need resurect the phone or no before write Full Dump ?
3) my phone is S5830, and I download this file : s5830-RedeYeS.bin , that is the correct one ?
4) for flash full dump I need select this if I'am not wrong (NOR/eMMC) :
5) I need check or no :
6) if no need check tell me if I need select on Data Length :
512 Mbytes of more ?
Best Regards,
JAVA Good.
Old 03-05-2013, 14:55   #14 (permalink)
Member: 399832
after erase phone need to repair boot fst then write full dump
YES this is working one
no you need to choose |Write full image into NAND
After Select Setting From Setting code No need to Select anything more
Page generated in 0.42532 seconds with 8 queries
