Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 05-26-2012, 00:38   #1 (permalink)
turca's Avatar
Member: 211017
Fullbackup P1000L
I need fullbackp P1000L, In torrent no have only P1000, thanks
Old 05-26-2012, 09:07   #2 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
I have full worked dump for P1000L
Please contact me on sonork...
What is your phone problem?
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post:
Old 05-28-2012, 21:23   #3 (permalink)
turca's Avatar
Member: 211017
I make flash with dump but error, after flash no power
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED
The DCCLoader USB Interface is not found. Communication continues over the DCC Interface
Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF
WARNING: Programming Error (0x24) at 0x000013FC0000 is Ignored.
WARNING: Programming Error (0x24) at 0x000014300000 is Ignored.
WARNING: Programming Error (0x24) at 0x000014380000 is Ignored.
WARNING: Programming Error (0x24) at 0x00001D3C0000 is Ignored.
WARNING: Programming Error (0x24) at 0x00001F5C0000 is Ignored.
Completed in 00:49:29.969 (Average Transfer Rate: 182.05 kB/s)
Old 05-28-2012, 21:36   #4 (permalink)
turca's Avatar
Member: 211017
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.32, JTAG Manager Version: 1.43
Selected Resurrector: [Samsung P1000N V1.0.0.0]
Connecting to the dead body...OK
Detected dead body ID: 0x1BA00477 - CORRECT!
Set I/O Voltage reads as 2.81V, TCK Frequency is 4 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Flashing the dead body...OK
Resurrection complete!
but no work only logo galaxy tab help-me
Old 05-29-2012, 07:54   #5 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
1....Uncheck USB DCC Loader
2....Erase Phone
3....Write Full Dump
Old 05-29-2012, 23:39   #6 (permalink)
turca's Avatar
Member: 211017
I make erase but error:
Set I/O Voltage reads as 2.78V, TCK Frequency is 4 MHz
Settings Code: 0x05010900000000000000000020000000
Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK
WARNING: Erasing Error (0x24) at 0x000013FC0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x000014300000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x000014380000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001D3C0000 is Ignored. Erase continues.
WARNING: Erasing Error (0x24) at 0x00001F5C0000 is Ignored. Erase continues.
Completed in 00:00:06.937 (Average Transfer Rate: 75578.49 kB/s)
After erase no flash correct, write 5%.. or write 80%...
I'll format my pc now to see if it improves
Old 05-30-2012, 14:37   #7 (permalink)
turca's Avatar
Member: 211017
No work error in flash:
Settings Code: 0x24010900000000000000000020000000
Completed in 00:48:58.453 (Average Transfer Rate: 184.00 kB/s)
Help-me
Old 05-30-2012, 14:48   #8 (permalink)
turca's Avatar
Member: 211017
No work error in flash: no power after flash
after Resurrection no power
After resurrection with gremlin phone power on, but freeze in logo Galaxy tab
Old 05-31-2012, 15:06   #9 (permalink)
turca's Avatar
Member: 211017
i need help, is possible or no! Thanks
Old 05-31-2012, 19:39   #10 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
I Think It's Possible if Hw is fine....
1-full erase(512mb)
2-Resurrect with P1000.dll or P1000N.dll( with and without select Gremlin zone)
3-You Should have a DL Mode after resurrect..
4-flash phone with odin by latest firmware....
Test and Post result
Old 06-01-2012, 00:27   #11 (permalink)
turca's Avatar
Member: 211017
Set I/O Voltage reads as 2.78V, TCK Frequency is 8 MHz
Settings Code: 0x05010B00000000000000000020000000
Completed in 00:00:05.984 (Average Transfer Rate: 87614.97 kB/s)
But no enter in download mode, I make other ressurection with Gremlin zone after in dl mode
<ID:0/087> Odin v.3 engine (ID:87)..
<ID:0/087> File analysis..
<ID:0/087> SetupConnection..
<ID:0/087> Initialzation..
<ID:0/087> Set PIT file..
<ID:0/087> DO NOT TURN OFF TARGET!!
<ID:0/087> Get PIT for mapping..
<ID:0/087> Firmware update start..
<ID:0/087> zImage
<ID:0/087> Sbl.bin
<ID:0/087> param.lfs
<ID:0/087> movinand.mst
<ID:0/087>
<ID:0/087> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Other error:
<OSM> All threads completed. (succeed 0 / failed 0)
<ID:0/087> Removed!!
<ID:0/087> Added!!
<ID:0/087> zImage
<ID:0/087> Sbl.bin
<ID:0/087>
<ID:0/087> Added!!
<ID:0/087> boot.bin
<ID:0/087> sbl.bin
<ID:0/087> zImage
<ID:0/087> factoryfs.rfs
<ID:0/087> dbdata.rfs
<ID:0/087> cache.rfs
<ID:0/087> modem.bin
<ID:0/087> hidden.rfs
<ID:0/087>
Old 06-01-2012, 14:52   #12 (permalink)
turca's Avatar
Member: 211017
New error:
Completed in 00:00:12.485 (Average Transfer Rate: 41993.43 kB/s)
<ID:0/087> zImage
<ID:0/087> Sbl.bin
<ID:0/087> boot.bin
<ID:0/087> Completed..
<OSM> All threads completed. (succeed 1 / failed 0)
<ID:0/094> Added!!
but I have this information in tablet
csc : deleting /system/csc
csc : done.
Successfully installed packpage.
Updating filesystem...
E:failed to mount /efs (invalid argument)
E:discard_filesystem_for_rfs:Can't mount /efs
--wiping cache...
Formatting /cache...
Cache wipe failed.
--Updating applications...
E:failed to mount /preload (No such file or direcotry)
E:install_application_for_customer:Canīt mount /preload
your storage not prepared yet, please use UI menu for format and reboot actions.
copy application failed
Appling Multi-CSC...
E:multi_csc: Canīt mount /efs
Is possible repair this p1000L?
Old 08-08-2012, 21:12   #13 (permalink)
Member: 434450
i also need this full can you share
Old 08-08-2012, 21:34   #14 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Hi
Please check:
[Important] RIFF Box Torrent Tracker -High Speed Files Download support
I need fullbackup of 6250 Invader Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 04-03-2002 05:41
Fullbackup and rolis 4.77 zauberflo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-05-2002 22:21
Fullbackup 6250 samson111 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-03-2001 08:56
Fullbackup 6210 5.27 need Schrifti Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 10-03-2001 13:00
Fullbackup need 6210 4.08 Schrifti Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-10-2001 02:25
Page generated in 2.78060 seconds with 11 queries
