06-20-2018, 17:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | G531H Resurrection OK but still dead Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.50 (RIFFBOX1), JTAG Manager Version: 1.79 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.41V, SD_CLK Frequency is 2.50 MHz Detected eMMC Chip, ID: 0x15/0x00 (QN1SMB), User Area Partition = 0x0001D2000000 Bytes (7.28 GB) Selected Resurrection Data for the eMMC Chip with Capacity = 7,28 GB Flashing the dead body...OK Resurrection complete! Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.50 (RIFFBOX1), JTAG Manager Version: 1.79 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.41V, SD_CLK Frequency is 2.50 MHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x15 OEM/Application ID ................... 0x00 Product Name ......................... "QN1SMB" Package .............................. BGA User Area Partition Size ............. 0x0001D2000000 Bytes (7.28 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000080000 Bytes (512.00 KB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x08, [162] = 0x00 Boot Configuration ................... Boot from Boot Partition 1 (Bus Width = 1Bit) Chip Revision ........................ 0.0 Multimedia Card Revision ............. 1.7 (eMMC v5.0) Serial Number ........................ 0x1B53D242 Memory Manufacturing Date ............ August, 2015 |
