11-27-2012, 21:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Galaxy Note N7000 - Error Code = 0x3E (0x007FFF <> 0x010000) Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.47 Selected Resurrector: [Samsung N7000 AP V1.0.4458.16492] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is 2 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported check many times wires, connections - phone is bricked after flashing custom rom. |
11-27-2012, 21:40 | #2 (permalink) |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Alredy read this: http://forum.gsmhosting.com/vbb/f634...ution-1508808/ make same, but phone still don't get up Same adreses are for i9000g and N7000 right? |
11-28-2012, 10:28 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Yes,But Can You Send Post Full Log..?Because I can see little diffrent in your first log -- Anyway,Address for ROM2 is same,Also you can write with different small chunks --- You can use from another pcb,if you have... |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
