07-02-2013, 07:37 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Maykop Age: 62
Member: 25492 Status: Offline Thanks Meter: 2 | Galaxy S4 L720 please help me After repair boot... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung L720 V1.0.4911.53799] Connecting to the dead body...OK Detected dead body ID: 0x2071B0E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G94, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G94, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB Flashing the dead body...OK Resurrection complete! I have problems with device drivers QHSUSB_DLOAD ! Please help me. |
07-02-2013, 10:37 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, If Your phone was killed by unlock or IMEI change, You'll need to reflash EFS data. Please contact me via ICQ or Sonork for further help. |
The Following 2 Users Say Thank You to legija For This Useful Post: |
08-11-2013, 11:54 | #5 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, With latest DLL, Total Repair option is included, You can select EFS and Modem partitions to be reflashed. |
The Following 5 Users Say Thank You to legija For This Useful Post: |
08-30-2013, 11:55 | #6 (permalink) |
Freak Poster Join Date: Jun 2005 Location: indonesia
Member: 154427 Status: Offline Thanks Meter: 61 | if i Resurrector with latest dll of l720 it can be repair meid? or i need to write full dump? my phone have empty meid...need repair meid or imei.. thanks.. |
08-30-2013, 12:58 | #7 (permalink) |
Member: 154427 Status: Offline Thanks Meter: 61 | still no imei after reflash modem and reflash efs partition selected.. still no imei, no meid, no baseband.. help bos legija... need your guide... here's the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung L720 V1.0.4970.39076] Connecting to the dead body...OK Detected dead body ID: 0x2071B0E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G94, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G94, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK Resurrection complete! Last edited by jupizet; 08-30-2013 at 13:04. Reason: add log.. |
08-30-2013, 13:41 | #8 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, It is possible that You need some samsung based tool to repair imei and checksums. There is probably new stronger protection now implemented. |
05-22-2014, 14:13 | #14 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung L720 V1.0.4970.39076] Connecting to the dead body...OK Detected dead body ID: 0x2071B0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G94, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G94, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 14.68GB Flashing the dead body...OK Resurrection complete! Still dead |
