06-11-2013, 11:19 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Location: London, UK Age: 38
Member: 164504 Status: Offline Thanks Meter: 17 | GND solder point won't take the solder I have a few Wildfire s motherboards where I can solder the other jtag wires (RTCK, TDI etc) with no problems except the GND solder point. I apply flux and apply solder but it does not stick. Is there an alternative GND that you can use? Thanks Sent from my Nexus 7 using Tapatalk 2 |
06-11-2013, 13:57 | #5 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | try scratching very gently with the point of exacto / surgical knife then flux and solder.... if that does not work just find another GND on the board. |
The Following User Says Thank You to spagman For This Useful Post: |
06-18-2013, 22:55 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Need Alternative GND?....You can Find In Anywhere in PCB Like Shield or any Resistor(1 Side is GND) |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
