03-04-2014, 15:23 | #17 (permalink) | |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | S3 mini i8190 Success Quote:
03-18-2014, 16:50 | #18 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
01-25-2016, 22:23 | #19 (permalink) |
Junior Member Join Date: Feb 2009
Member: 980136 Status: Offline Thanks Meter: 1 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
05-17-2016, 00:44 | #20 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1557159 Status: Offline Thanks Meter: 5 | Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
