12-09-2012, 12:20 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1057960 Status: Offline Thanks Meter: 6 | GT-I8190 S3 mini pinout detected Ive detected jtag pinout fot this model : http://img51.imageshack.us/img51/8242/jtagpads.jpg Pads are locate under battery, so please remove coat carefully. CPU : ST-Ericsson NovaThor U8500 Voltage : 1.8 Hi Legija, unfortunatelly this model isnt supported yet. Also U8500 doesnt have direct memory access like PXA270 in plugin Please could you create dll and direct memory access for this model too ? My tests with current available DCCs based on U8500 units : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4705.16773] Connecting to the dead body...OK Detected dead body ID: 0xFBFFFFFF - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Settings Code: 0x00010E00000000000000000008000000 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Custom Target: [NOVATHOR U8500, 1.80V, TAP0] Connecting to the NOVATHOR U8500 target...OK Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Target ID on TAP0: 0xFFFEFFFF - Connected OK Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Custom Target: [NOVATHOR U8500, 1.80V, TAP0] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #1: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #2: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #3: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #4: ID = 0x00000001, IR Length = 0x02 bits Total IR length: 0x0006 bits |
12-09-2012, 18:42 | #2 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Kz Age: 59
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | it seems you are mix up TMS and TDI, so analize chain log is not correctly, device ID=FFFFFFFF. Try to get correct target ID and then NRST. But, thanks anyway. Best Regards. Last edited by Nicolayer; 12-09-2012 at 18:49. |
12-10-2012, 21:44 | #3 (permalink) |
Member: 1057960 Status: Offline Thanks Meter: 6 | Hi Nicolayer, pinout is correct, but issue was caused by drivers. After pseudo Novathor USB Rom drivers installation, ID was detected correctly : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Custom Target: [NOVATHOR U8500, 1.80V, TAP0] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x05 bits Device on TAP #1: ID = 0xFFFFFFCF, IR Length = 0x01 bits Device on TAP #2: ID = 0xFFFFF7FF, IR Length = 0x01 bits Device on TAP #3: ID = 0xBFFFFFFF, IR Length = 0x01 bits Device on TAP #4: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #5: ID = 0x000000FF, IR Length = 0x01 bits Total IR length: 0x000A bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x4BA00477: Samsung S5PV300 2. 0x4BA00477: NovaThor U8500 3. 0x4BA00477: Generic CORTEX-A9 OOpen serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4705.16773] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Settings Code: 0x00000E00000000000000000008000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Custom Target: [NOVATHOR U8500, 1.80V, TAP0] Connecting to the NOVATHOR U8500 target...OK Detected Target ID on TAP0: 0x4BA00477 Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Settings Code: 0x00000E00000000000000000008000000 Resurrection sequence started. Establish communication with the phone...OK Uploading loader data into memory...FAILED ERROR: Memory at given address cannot be Written. |
12-13-2012, 22:06 | #5 (permalink) |
Member: 1057960 Status: Offline Thanks Meter: 6 | With that low frequnce relatively unstable. Best seems to 8MHz See details : Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM08G, 0x0001D2000000 Bytes = 7.28 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM08G, 0x000000200000 Bytes = 2.00 MB) ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 7,28GB |
The Following User Says Thank You to pitka For This Useful Post: |
01-02-2013, 22:05 | #7 (permalink) |
Member: 1057960 Status: Offline Thanks Meter: 6 | Hi Legija, in attached link you can find working dumps by partitions for I8190, you can use it for compilation : UploadMB.com |
08-12-2013, 18:43 | #14 (permalink) | |
Junior Member Join Date: May 2008
Member: 766928 Status: Offline Thanks Meter: 2 | how to creat dll Quote:
09-23-2013, 08:19 | #15 (permalink) |
Major Poster Join Date: Dec 2012 Location: This is not my familiar forum
Member: 1849224 Status: Offline Sonork: no ida Thanks Meter: 5 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
