07-01-2013, 12:14 | #1 (permalink) |
Junior Member Join Date: Oct 2010 Location: Arabia Is My Homeland Age: 43
Member: 1408067 Status: Offline Sonork: 100.1605560 Thanks Meter: 11 | GT-I8530 Dead boot Resurrection problem i have problem with this model GT-I8530 its dead after wrong flashing ,,, when i try to fix it with riff its show this error and i research for any solution here but i didnt found any thing about it ... any body fix this model befor with riff ???? help please Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I8530 V1.0.4705.16748] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. |
09-17-2013, 18:52 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: pakistan
Member: 683063 Status: Offline Sonork: 100.1617868 Thanks Meter: 136 | i am try but error this Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.51 Selected Resurrector: [Samsung I8530 V1.0.4705.16748] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
09-18-2013, 08:29 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | Its hardware problem for sure if wires are soldered well.I have done one set ok by removing a modem ic.if u post the pcb i will mark it.but the set will be blank imei after that u have to replace that ic to restore imei. Hope this helps in your case. sajid mirza. |
