04-09-2013, 08:38 | #1 (permalink) |
Major Poster Join Date: Jul 2012
Member: 1789765 Status: Offline Thanks Meter: 7 | GT-P5100 boot repair problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung P5100 XLoader+ V1.0.4773.9895] Connecting to the target...OK Set I/O Voltage reads as 2.60V, TCK Frequency is 8 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFE, IR Length = 0x06 bits Total IR length: 0x0006 bits ******************************************** If try to Resurrect the phone: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung P5100 XLoader+ V1.0.4773.9895] Connecting to the dead body...FAILED None is detected. I don't know the story of the tablet.. What's the problem? Maybe i need different resurrector DLL ( XLoader- )??? or it's a flash problem?? Thx in advance |
04-09-2013, 12:22 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Xloader is deleted or not accessible, so JTAG is not enabled. You should try to find omapflash package for this phone (like for i9100G). |
The Following User Says Thank You to legija For This Useful Post: |
04-09-2013, 20:40 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I Have Somthing For P5110 and P5113(Omap Flasher)...But I Think We Can Use For P5110 Please Contact Me Via Sonork For Tets This SW Thanks |
04-14-2013, 22:26 | #6 (permalink) |
Junior Member Join Date: Mar 2006
Member: 239082 Status: Offline Thanks Meter: 0 | Did you found any solution to unbrick P5100. I have one P5100 with broken Xloader so unbrick with RIFF failed and i've tried with different versions/configs of OMAPFlash - nothing works. Looks like impossible to repair P5100 with deleted XLOADER |
04-17-2013, 22:11 | #7 (permalink) |
Member: 239082 Status: Offline Thanks Meter: 0 | Guys, is it impossible to unbrick P5100 with broken XLOADER with RIFFBOX? Also no solution found with Omap Flasher. I'm correct - we can't unbrick this device when XLOADER broken? |
09-30-2013, 12:55 | #8 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2037095 Status: Offline Sonork: bluemind Thanks Meter: 0 | P5100 completely dead Quote:
I got a P5100 went to die during normal usage (i was just surfing on the web and then the P5100 turned off and never it started up again). Any chance to try your SW with my Tab P5100? Many thanks in advance. | |
04-17-2014, 23:59 | #9 (permalink) |
Junior Member Join Date: Jul 2013 Location: Oregon
Member: 1980130 Status: Offline Thanks Meter: 0 | I also would like to try the omap flash package on my Tab 2 10.1 although my model is SGH-T779 which is same variants of P5100 etc does it matter? I get QHSUSB_DLOAD driver error when plugging in the tab with usb. |
04-06-2016, 08:24 | #11 (permalink) |
Freak Poster Join Date: Mar 2009 Location: 75.BAITUN NOOR SHOPPING CENTER
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung P5100 XLoader+ V1.0.4773.9895] Connecting to the dead body...OK Detected dead body ID: 0x3BA00477 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000034 No Resurrection Data is available for the eMMC Chip with Capacity = 0B WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 14.68GB ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
