GT-S6102 how to boot repair ? i have samsung gt-s6102 hang in logo only i try to flash to SPT box now the phone is dead boot i try to repeir to RiFF box but cannot ressurected itry setting RCTK SAMPLING to all MHZ setting but same error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.46 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...ERROR ERROR: No response from the RIFF Box. |
Hi Please check soldered wires Connect usb cable Connect power supply ----- RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. Please test with "RTCK Sample at Max" or TCK 6Mhz |
hi i try this Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.46 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
1 Attachment(s) Hi Set TCK speed at 6mhz(no rtck),or any other speed But,Please check soldered wires,,or resolder again all wires.. -- What is phone history? |
hi all setting RTCK Sampling JTAG wires are of the SAME LENGTH I solder very well the wire but same error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.46 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
the phone hang in logo i flash in spt box but error now the phone is dead boot or cannot boot Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.46 Selected Resurrector: [Samsung S6102 V1.0.4640.6533] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 6 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
hi i update this thread as now cannot solved my problem RIFFBOX team please solve my problem |
Hi Please contact me via sonork with connected phone to Riff-Box |
WBR ReyTech. |
Samsung S6102 dead in flash time help us for boot repair Error in Rilf box Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. help for boot replair .. this phone update time dead |
