10-29-2010, 11:21 | #3 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, This model is not supported at the moment. Also, as it seems, JTAG access is disabled in LG production phones. However, You can send Your PCB to our dev team for test. Contact me by PM for more details. |
02-12-2011, 19:01 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 48
Member: 110088 Status: Offline Thanks Meter: 29 | Gt540 boot done- flash KDZ not work hello I fixed the boot in the gt540 but I can not program this lg The phone comes in a download mode, sees the computer installs the modem and com port. Still crashes when programming error. Here is the log of the KDZ [16:09:31:984] : ============================================= [16:09:32:000] : Log is started on 11.02.2011, at 16:09:31:984, executable: E:\gt540\KDZ FW UPD EN\KDZ_FW_UPD_EN\KDZ_FW_UPD.exe (ProcID: 0x00000f84), compile time : Sep 8 2010 17:19:53 [16:09:32:000] : Version : [16:09:32:000] : strFilename1 = V20 [16:09:32:000] : m_DlMode = 4, m_strBinaryPath = C:\Documents and Settings\All Users\Dane aplikacji\LGMOBILEAX\Phone\DZ_GT540AT-00-V20a-APP-XX-OCT-05-2010+0.dz, m_nSelectedImages= 70787108 [16:10:34:734] : Start Web Downloading [16:10:34:765] : Get Usb Port [16:10:35:984] : rsi.strFriendlyName=Port komunikacyjny (COM1) [16:10:36:000] : Remove Port komunikacyjny (COM1) [16:10:36:000] : rsi.strFriendlyName=Z3X BOX Serial Port (COM4) [16:10:36:000] : Remove Z3X BOX Serial Port (COM4) [16:10:36:000] : rsi.strFriendlyName=RIM Virtual Serial Port v2 (COM165) [16:10:36:000] : Remove RIM Virtual Serial Port v2 (COM165) [16:10:36:000] : rsi.strFriendlyName=LGE Android USB Serial Port (COM168) [16:10:36:000] : FriendlyNameList[iii].szFriendlyName=LGE Android USB Serial Port [16:10:36:031] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 1 - COM168 [16:10:36:031] : Port = COM168 [16:10:36:031] : Clear [16:10:36:046] : Clear [16:10:36:046] : UNKNOWN : Req(12) -> Rsp(13) [16:10:36:046] : Clear [16:10:36:046] : UNKNOWN : Req(12) -> Rsp(13) [16:10:36:046] : Clear [16:10:36:062] : UNKNOWN : Req(12) -> Rsp(13) [16:10:36:062] : >> DIAG_STATUS_F FAILED [16:10:36:062] : >>Get Model Name [DIAG_VERNO_F] [16:10:36:062] : Clear [16:10:36:062] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:062] : Clear [16:10:36:062] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:062] : Clear [16:10:36:062] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:062] : Clear [16:10:36:062] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:062] : Clear [16:10:36:078] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:078] : Clear [16:10:36:078] : BAD CONN MODE : Req(0) -> Rsp(3) [16:10:36:078] : FAIL (No Phone) [16:10:36:078] : GetModelName() Operation Failed Check Diag CMD [16:10:36:078] : EMERGENCY Booting Mode [16:10:36:078] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F] [16:10:36:078] : Clear [16:10:36:078] : Clear [16:10:36:078] : BS/GT540/7Dinformation [16:10:36:078] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 0 - GT540 [16:10:36:078] : >>Get Mobile SW [DIAG_EXT_BUILD_ID_F] [16:10:36:078] : Clear [16:10:36:078] : Clear [16:10:36:078] : DLOAD_NAK_F reason_msb = 6, reason_lsb = 6 [16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_CMD [16:10:36:078] : Clear [16:10:36:078] : DLOAD_NAK_F reason_msb = 6, reason_lsb = 6 [16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_CMD [16:10:36:078] : Clear [16:10:36:078] : DLOAD_NAK_F reason_msb = 6, reason_lsb = 6 [16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_CMD [16:10:36:078] : FAIL [16:10:36:078] : Phone_Diag_Status = FALSE [16:10:36:078] : Clear [16:10:36:078] : Clear [16:10:36:078] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3 [16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_LEN [16:10:36:078] : Clear [16:10:36:078] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3 [16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_LEN [16:10:36:078] : Clear [16:10:36:093] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3 [16:10:36:093] : [ DLOAD ERROR ] : NAK_INVALID_LEN [16:10:36:125] : NV Write Fail : NV ITEM 9028(9028) [16:10:36:234] : m_pPhoneCtrl->m_pDload->Dl_GetCommMode(&m_pPhoneCtrl->m_pDload->m_nCommMode) [16:10:36:234] : >> GET DLOAD COMM MODE [16:10:36:234] : Clear [16:10:36:234] : Clear [16:10:36:234] : [GetCommMode] Communication mode : 2 [16:10:36:250] : Pre Nand Download [16:10:36:250] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted) [16:10:36:250] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 3 - TRUSTED MODE [16:10:36:250] : Clear [16:10:36:250] : Clear [16:10:36:250] : [COM168] >>NandFlashInitWithFile(PARTITION TBL), BinType =8 [16:10:36:250] : NandFlashInitWithFile :: LG3GBinaryList[BinType].szBinaryTypeName = PARTITION TBL, BinType = 8 [16:10:36:250] : NandFlashInitWithFile :: [16:10:36:250] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 3 - INIT PARTITION TBL [16:10:36:250] : Clear [16:10:36:250] : Clear [16:10:36:265] : Clear [16:10:36:265] : Clear [16:10:36:265] : ¸Ţ˝ĂÁö ş¸łż TYPE_WPARAM_WRITE_TO_SDRAM 3 [16:10:36:265] : m_nSelectedImages= 70787108,Type= 3 [16:10:36:265] : [COM0] ¸Ţ˝ĂÁö ş¸łż TYPE_WPARAM_WRITE_AMSS 15 [16:10:36:265] : [COM168] >>NandFlashInitWithFile(AMSS MODEM HEADER), BinType =14 [16:10:36:265] : NandFlashInitWithFile :: LG3GBinaryList[BinType].szBinaryTypeName = AMSS MODEM HEADER, BinType = 14 [16:10:36:265] : NandFlashInitWithFile :: [16:10:36:296] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 3 - INIT AMSS MODEM HEADER [16:10:36:296] : Clear [16:10:36:296] : Clear [16:10:36:296] : >> AMSS FLASHING ... [16:10:36:296] : ¸Ţ˝ĂÁö ş¸łż ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0 [16:10:36:328] : Sending Pkt Seq : 0 [16:10:36:328] : Clear [16:10:36:328] : Sending Pkt Seq : 1 [16:10:36:328] : Sending Pkt Seq : 2 [16:10:36:328] : Sending Pkt Seq : 3 [16:10:36:328] : Sending Pkt Seq : 4 [16:10:36:328] : Sending Pkt Seq : 5 [16:10:36:328] : Sending Pkt Seq : 6 [16:10:36:328] : Sending Pkt Seq : 7 [16:10:36:328] : Sending Pkt Seq : 8 [16:10:36:328] : Sending Pkt Seq : 9 [16:10:36:328] : Sending Pkt Seq : 10 [16:10:36:328] : Sending Pkt Seq : 11 [16:10:36:328] : Sending Pkt Seq : 12 [16:10:36:328] : Sending Pkt Seq : 13 [16:10:36:328] : Sending Pkt Seq : 14 [16:10:36:328] : Sending Pkt Seq : 15 [16:10:36:328] : Sending Pkt Seq : 16 [16:10:36:328] : Sending Pkt Seq : 17 [16:10:36:328] : Sending Pkt Seq : 18 [16:10:36:328] : Sending Pkt Seq : 19 [16:10:36:328] : Sending Pkt Seq : 20 [16:10:36:328] : Sending Pkt Seq : 21 [16:10:36:328] : Sending Pkt Seq : 22 [16:10:36:328] : Sending Pkt Seq : 23 [16:10:36:328] : Sending Pkt Seq : 24 [16:10:36:875] : Error Read in WaitRsp [16:10:36:875] : Sending Pkt Seq : 25 [16:10:36:968] : Error Read in WaitRsp [16:10:36:968] : Sending Pkt Seq : 26 [16:10:36:968] : @@ Cable Disconnected - Writing : 5 [16:10:36:968] : Clear [16:10:36:968] : WM_COPYDATA ¸Ţ˝ĂÁö ş¸łż 3 - Close Port [16:10:36:968] : Close Port<< [16:10:36:968] : [COM0] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH [16:10:36:968] : TYPE_WPARAM_UPGRADE_ERROR [16:10:36:968] : ¸Ţ˝ĂÁö ş¸łż - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008 [16:10:37:156] : Log finished |
The Following User Says Thank You to gadzetxp For This Useful Post: |
02-21-2011, 20:59 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Same problem here! After repair boot,phone can go to download mode ,pc can detect but flashing not work! I try to flash with original flasher and vygis software too! |
03-02-2011, 13:56 | #9 (permalink) |
Registered User Join Date: Jul 2006 Location: iphone ww codes Age: 42
Member: 305964 Status: Offline Thanks Meter: 71 | help GT540 dead boot mr product supported help me about lg gt540 deadboot always like jtag connected properly can help me about the settings Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory access timed out. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory access timed out. Last edited by maryajne; 03-02-2011 at 14:02. |
03-02-2011, 14:13 | #10 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: china
Member: 817951 Status: Offline Sonork: 100.1584874 Thanks Meter: 52 | Quote:
gt540 repair only use usb cable ! chk it gnd have good conneted? i can use TeamViewer help u !if u want help .please contact me Sonork: 100.1584874 b.r hhrj | |
03-03-2011, 04:24 | #11 (permalink) |
Member: 305964 Status: Offline Thanks Meter: 71 | up this thread help me please Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 3 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: DCC Loader Execute failed. Terminating. error like this Last edited by maryajne; 03-03-2011 at 04:30. |
03-03-2011, 04:32 | #12 (permalink) |
Member: 305964 Status: Offline Thanks Meter: 71 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.18, JTAG Manager Version: 1.26 Selected Resurrector: [LG GT540] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 100 kHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data length received. |
03-17-2011, 10:44 | #15 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 682583 Status: Offline Thanks Meter: 0 | aa i forgot about importand thing lcd looks like dead when i power it on . And one more thing phone when is going to download mode is unrecognized device and i assume becouse of that i cant flash it .. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
