07-25-2014, 01:26 | #1 (permalink) |
Major Poster Join Date: May 2013
Member: 1938255 Status: Offline Thanks Meter: 28 | Help Backup ROM1 for jtag Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC OneM7 U (PN0711000) V1.0.5046.47163] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x0C010000000000000000000747FFFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HBG4E, 0x000748000000 Bytes = 29.13 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HBG4E, 0x000000400000 Bytes = 4.00 MB) Reading FLASH1 address space from 0x000000000000 to 0x000747FFFFFF ERROR: Read Failed with Error Code: 0x28. Terminating at 0x000011C40000 autoflash size, Read |
09-05-2014, 11:58 | #2 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 755471 Status: Offline Thanks Meter: 18 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC OneM7 (PN0713000) V1.0.5149.50216] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Settings Code: 0x20010009000000000000000010000000 Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. Anyone can help? the Error |
