04-25-2013, 17:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | help with i8160p !! now phone not connect with jtag Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the dead body...FAILED None is detected. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the dead body...OK Set I/O Voltage reads as 1.81V, TCK Frequency is 12 MHz Detected dead body ID: 0x4BA00477 Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I8160 V1.0.4705.16807] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x4BA00477, IR Length = 0x05 bits Device on TAP #1: ID = 0xFFFFFFCF, IR Length = 0x01 bits Device on TAP #2: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #3: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #4: ID = 0xFFFFFFFF, IR Length = 0x01 bits Device on TAP #5: ID = 0x000000FF, IR Length = 0x01 bits Total IR length: 0x000A bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x4BA00477: Generic CORTEX-A9/A15 Core Based Target |
04-25-2013, 23:32 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You Need Connect Phone To PC Via USB Cable and Install Driver From RIFF Directory 1-Connect Phone to RIFF 2-Connect USB To Phone 3-Install Driver (U8500 ST-Ericsson) 4-Press "Resurrection" 5-Quickly Put Battrey to Phone |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
04-26-2013, 09:00 | #3 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | thx for help but not success with this phone repaired with solder jtag/battrie connect/press poweron/ without usb if usb connected no connection with phone(driver installed) |
