05-02-2013, 10:36 | #1 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893471 Status: Offline Thanks Meter: 25 | Help I9023" ERROR: RAM memory selftest failed" Samsung I9023 cannot boot repair, following is log Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9023 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 40 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. Please suggest to solve issue. thanks Best regards, |
05-02-2013, 10:40 | #2 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | I also try this method from FAQ but failed RIFF JTAG Box FAQ - ERROR: RAM memory selftest failed. |
05-02-2013, 10:44 | #3 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | it is mentioned in FAQ page "Easiest was to diagnose this is to run generic DCC loader DLL. Generic DLL-s use internal MCU SRAM, and in case that You can boot target device without problems using generic DLL, and with model specific You have this error, it's hardware problem." Where to download generic.dll? I could not found on support |
