03-10-2016, 00:24 | #1 (permalink) |
Insane Poster Join Date: Oct 2013
Member: 2055268 Status: Offline Thanks Meter: 5 | help me, my problem s5570i if so, then you seem to have set wrong setting. please double check carefully. valid settings while flashing full dumps would be: 1. image file is used-for nand-checked, for nor-not checked!!!! 2. use address as offset-does not matter 3. auto fullflash size-does not matter, but for ease better to be checked 4. ECC module enabled-must be not checked (yes, unchecked) apakah ada settingan saya yanf salah?? |
03-10-2016, 00:25 | #2 (permalink) |
Member: 2055268 Status: Offline Thanks Meter: 5 | I have a samsung phone s5570i. when I want to flash a dump file out warnings like this. seems you are trying to flash a full dump into phone ?? if so, then you seem to have set wrong setting. please double-check carefully. Invalid settings while flashing full dumps would be: 1. The image file is used-for nand-checked, for nor-not checked !!!! 2. use the address as offset does not matter 3. auto flash full-size does not matter, but for ease better to be checked 4. ECC-enabled module must be not checked (yes, unchecked) is there a setting I wrong ?? |
