08-01-2017, 09:56 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2692092 Status: Offline Thanks Meter: 0 | Help me repair partition emmc Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.46 (RIFFBOX1), JTAG Manager Version: 1.70 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 1.81V, SD_CLK Frequency is 2.50 MHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x15 OEM/Application ID ................... 0x00 Product Name ......................... "000000" Package .............................. BGA User Area Partition Size ............. 0x000000000000 Bytes (0.00 KB) Boot Partition Size .................. 0x000000080000 Bytes (512.00 KB) RPMB Partition Size .................. 0x000000020000 Bytes (128.00 KB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE Boot Configuration ................... No Boot Chip Revision ........................ 5.6 Multimedia Card Revision ............. 1.5 (eMMC v4.41) Serial Number ........................ 0x20140314 Memory Manufacturing Date ............ May, 2016 AND CAN NOT WRITE ANY, CID, CSD, EXTCSD ALWAYS FAIL Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.46 (RIFFBOX1), JTAG Manager Version: 1.70 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 1.81V, SD_CLK Frequency is 2.50 MHz Detected eMMC Chip, ID: 0x15/0x00 (000000), User Area Partition = 0x000000000000 Bytes (0.00 KB) Writting CSD Register...ERROR ERROR: Writting CSD Register Failed (ERR[0071], POS[0001]) |
