02-04-2019, 13:28 | #1 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2511098 Status: Offline Thanks Meter: 41 | Help with mtk interface WHICH DOESNT ACCPET FLASH AFTER TRYING TO FLASH PRELOADER BY THE LOG THE RIFF IS ONLY CHECKING ON QCOMM DEVICE AND IVE LOADED AN AMTK SCATTER IT ONLY SAYS Connecting to the Device via USB Interface...ERROR ERROR(1): Cannot Find Qualcomm HS-USB QDLoader Interface COM Port |
02-07-2019, 09:26 | #2 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: Dombivli (E) Age: 48
Member: 124938 Status: Offline Thanks Meter: 69 | Quote:
Use DA from SP Flashtool and Preloader.bin from the downloaded firmware. Save the repair pack. Use it with eMMC plugin. To create custom profile/package, follow simple steps: - Click "Create Repair Package" on "Box Service" TAB - Click "Add action" - Select "Establish USB Connection" - Select "Mediatek Bootrom" and "Mediatek DA Protocol", "eMMC" and of course load DA and preloader files. (preloader can be from firmware, or bootpartition 1 dump) - Click "OK" and "Save Package". If You with to add write actions, select "Write to flash via USB/ISP" and use eMMC plugin to automatically select partitions and address. If everything is fine, it should work Best regards ~Aju | |
