10-02-2012, 20:49 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi If Phone is on,No need SD_Magic if Phone is dead,Needed SD_MAgic --- Anyway, if you want write only efs partition.Just check soldered wires(remove socket from pcb is good idea)...check usb and power supply Also,Please select IRAM dll...and speed at 8 or 6 mhz |
10-02-2012, 23:17 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Online Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
did u try to repair it with spt if u have..? flash with 2.3.3 then repair efs and spt mode and factoy mode.. if RF chip is fine after repair default efs phone imei will be 0049... if nothing change, still null i think RF ic bad and u have to replace it.. w.b.r. | |
10-03-2012, 09:27 | #11 (permalink) | |
No Life Poster Join Date: Nov 2008
Member: 901472 Status: Offline Thanks Meter: 48 | Quote:
10-03-2012, 10:00 | #13 (permalink) |
Member: 901472 Status: Offline Thanks Meter: 48 | box version 1.44 not stable hi, Im using a same computer,box,power supply and phone.I solder everything and try write efs files.try after tries power off and on power supply at last riff box found my phone and successful write efs.I also tried analyze chain also okay but when i turn off power supply and turn it back on to try analyze chain " phone not detected " im using main usb for riffbox.what is my problem? BR |
