07-14-2013, 14:26 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: iran Age: 46
Member: 652684 Status: Offline Thanks Meter: 20 | help with repair boot lg e615 plz any solution the phone waz alive before flash and kill it Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [LG E615 V1.0.4836.62391] Connecting to the dead body...OK Detected dead body ID: 0x106040E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (G40MES, 0x0000EC000000 Bytes = 3.69 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (G40MES, 0x000000100000 Bytes = 1.00 MB) ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 3.69GB and with low speed Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [LG E615 V1.0.4836.62391] Connecting to the dead body...OK Detected dead body ID: 0x106040E1 - IGNORED! Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init |
07-15-2013, 06:48 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Your Problem is "ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 3.69GB " Do You Have Another Working Phone With Same Size eMMC ???? |
