09-27-2012, 15:58 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: kl Age: 40
Member: 151678 Status: Offline Thanks Meter: 22 | help to repair incredible s pcb look fine but error on repair boot Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [HTC Incredible S V1.00] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (M4G2DE, 0x000086800000 Bytes = 2.10 GB) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x00000008D200 |
09-27-2012, 23:29 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi This is clear type of faulty eMMC... i have few phone like you(all repaired after replace) ----- This is "M4G2DE".....for some case maybe can write with plugin or DCC Read/Write Page....if you can,please try repartition,then write dump....1% Maybe help |
