11-20-2019, 16:43 | #1 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Help Riff box boot sony LED TV BOOT KDL-43W755C KDL-43W756C KDL-43W800C KDL-43W805C KDL-43W807C KDL-43W808C KDL-43W809C KDL-50W755C KDL-50W756C SONY KDL-55W805C BOOT dead Mainboard 1-980-805-31 Chip EMMC Samsung KLMAG2GEND-B031 SK hynix H26M52103FMR Toshiba THG8MBG702KBAIL info Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.53 (RIFFBOX1), JTAG Manager Version: 1.87 Selected Manual Mode: [Qualcomm DMSS, External Binary Format File, MediaTek DA] Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 3.20V, SD_CLK Frequency is 40 KHz Memory Identification Info Memory Type: eMMC Manufacturer ID: 0x90 (HYNIX) OEM/Application ID: 0x4A Product Name: "HAG2e " Package: BGA Memory Capacity and Geometry Info User Area Partition Size ............. 0x0003AB800000 Bytes (14.68 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) CID Register ......................... 90014A48414732650503567B4A4053C1 CSD Register ......................... D02701320F5903FFFFFFFFEF8A4040D3 Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x0D, [179] = 0x00, [162] = 0x00 Boot Configuration ................... No Boot Chip Revision ........................ 0.3 Multimedia Card Revision ............. 1.7 (eMMC v5.0) Serial Number ........................ 0x567B4A40 Memory Manufacturing Date ............ June, 2016 Memory Health Information Device life time reflected by Reserved Blocks - NORMAL Estimated wear out of MLC Memory - Wear out: 0%..10%, Lifetime remaining: 90%..100% Estimated wear out of SLC Memory - Wear out: 0%..10%, Lifetime remaining: 90%..100% Last edited by Nurettin Duman; 11-20-2019 at 16:48. |
The Following 3 Users Say Thank You to Nurettin Duman For This Useful Post: |
11-25-2019, 07:05 | #2 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Quote:
Boot Partition 2 Is empty (Red Area ) Code: ExtCSD Register Fields ............... [177] = 0x0D, [179] = 0x00, [162] = 0x00 Please fill boot area 2 Example:- Boot area MTK Then boot configuration = [179] = 0x48 | |
11-25-2019, 14:50 | #3 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | hallo not suport Chip EMMC Samsung KLMAG2GEND-B031 |
03-17-2020, 07:33 | #4 (permalink) |
Major Poster Join Date: Jan 2019
Member: 2887331 Status: Offline Thanks Meter: 2 | Hello, after programming the new eMMC memory Netflix and the CI module does not work. I need to copy keys from corrupted eMMC memory. Does anyone know where these keys are in the binary file? |
04-24-2020, 15:15 | #5 (permalink) |
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | hello where did you find full dump flash ask if you did send full dump flash and what box wrote |
