11-08-2012, 15:41 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: bizerte tunisie Age: 38
Member: 1578225 Status: Offline Thanks Meter: 17 | help s5560i Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [Samsung S5560i V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x05010000000000000000000010000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Erasing FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x0000048E0000 is Ignored. Erase continues. Completed in 00:00:10.234 (Average Transfer Rate: 25615.01 kB/s) after Erasing flash full dump Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [Samsung S5560i V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x25010000000000000000000010000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Writting FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x0000009C0000 |
