06-24-2014, 10:02 | #1 (permalink) |
Junior Member Join Date: Jun 2014 Location: INDONESIA
Member: 2208518 Status: Offline Thanks Meter: 0 | HELP s5570 dead boot ok but phone just stuck on downloading mode |
06-24-2014, 10:09 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | it means you have successfully repaired you phone's dead boot because now its booting up and now its time to flash stock firmware into phone. |
The Following User Says Thank You to androidlabs For This Useful Post: |
06-24-2014, 10:11 | #3 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | [TUT]Official Gingerbread 2.3.6 05.05.2012 GalaxyMini s5570~ODIN~UPDATED - xda-developers here is the way to flash stock rom on your device. Good luck |
06-25-2014, 09:36 | #5 (permalink) | |
Member: 2208518 Status: Offline Thanks Meter: 0 | here this log brother i try write dump file Quote:
06-25-2014, 09:38 | #6 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | After boot repair you must flash with pit which in your case is ops file on odin you need to load ops file and select repartition flash then remove ops file and unselect repartition then flash full original firmware downloaded from samfirmware good luck |
