10-07-2013, 10:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Dhahran ph
Member: 334094 Status: Offline Sonork: none Thanks Meter: 73 | hi riffbox team pls hlp htc one x dead boot only.. i try repair riffbos hr the logs Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.54 Selected Resurrector: [HTC OneX (PJ8310000) V1.0.4800.54064] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! |
