10-21-2012, 10:25 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | How to Repair HTC One V imei............ how to repair / change Htc One V imei with riff. i resurrected the phone. And there is no option for Unlock, Super CID, Imei repair, etc.......... how to work with this......... |
10-22-2012, 00:03 | #3 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
You Think "Resurrect" Done .....? --- As far as I see in your photo, Phone never detected correctly --- You need Use TP....Then Press Resurrect... if you done correct TP,You Can see new window and you can select any needed option,like Imei/CID/Sbl/Recovery/Htc Partition | |
10-22-2012, 09:11 | #4 (permalink) |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Supporter... thanks for your reply. but how the port was identified, if the TP is incorrect. And why it is showing, resurrector job is finished. |
10-22-2012, 13:06 | #5 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Many phone can detect as QHUSB_DLOAD Mode Without TP....But This is incorrect --- Also for some case you need try few times for correct detect... --- Please Note: Quote:
http://forum.gsmhosting.com/vbb/f634...ation-1464870/ | |
10-24-2012, 15:37 | #6 (permalink) |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Supporter....... after multiple tries,tthe phone was resurrected. But unable to flash rom, it always showing "Bootloader - Failed PU" for all rom. Also changed cid to 11111111. I tried by resurrecting only by selecting Repair Recovery Zones, but the phone is not going to recovery to flash custom rom. Unable to flash cwm recovery, superboot.img from fastboot command, signature verify failed. Phone is bootloader unlocked......... Need solutions............... |
10-24-2012, 16:19 | #7 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | If You wanted just to repair IMEI, all what You had to do is to tick just IMEI repair option, and untick everything else. By default, "generic resurrection" is enabled, and You had to untick that option. As i know, You cant flash phone with RUU if phone is S-Off. |
10-24-2012, 16:56 | #10 (permalink) | |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
I accidently forgot to untick generic resurrection before changing imei. Will it possible to alive after restoring original imei to phone and what about original serial number after writing original imei. the phone is bootloader unlocked and still it is "S-On"... | |
10-24-2012, 17:29 | #12 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | There is One V full flash at RIFF torrent tracker. It's not good idea to write full flash just like that - you can resolve your problems in easier way. Download full flash, open it in eMMC plugin, and upload following partitions into Your phone: DBL, OSBL, AMSS, SPL, Boot, Recovery. After this - You should be able to use either RUU updater, or receovery menu. This model is based on MSM8255 cpu. Instructions for eMMC plugin You can read here: RIFF JTAG Box FAQ - How to use QUALCOMM eMMC MBR/EBR Partitioning plugin |
The Following User Says Thank You to legija For This Useful Post: |
10-25-2012, 11:47 | #13 (permalink) |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Sir, It is necessary to select repartition emmc before partitioning selected partion. how to multiple select the partition? After flashing selected partition, do i have to run Stock rom or custom rom from from recovery. |
10-25-2012, 13:30 | #14 (permalink) |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Sir i flashed selected partion to phone, after that ruu is not flashing. So i tried injecting hboot_1.15.0003_2318182b_0303.img to SPL and flashed DBL,OSBL,SPL. Now the phone has HBOOT 1.15.0003. Like this shall i flash Super boot.img and Custom recovery to phone, so that i can flash custom rom if the phone goes to recovery. Need instruction, please............. Last edited by ashamsu; 10-25-2012 at 13:34. Reason: To Add Attachment |
