07-16-2013, 16:17 | #1 (permalink) |
Junior Member Join Date: Dec 2010 Location: islam land
Member: 1477270 Status: Offline Sonork: specter16 Thanks Meter: 1 | how to repaire RADIO img HTC SENSATION XE with JTAG? i flashed a corrupted radio img to my htc sensation xe now i'm stuck into bootloader check out my case HERE i JTAGED my htc but i didn't flash radio via JTAG now i'm still stuck in boot loader ------------------------------------------------------------ BEFORE JTAG *** LOCKED *** PYRAMID PVT SHIP S-OFF RL HBOOT-1.29.0000 eMMC-boot Mar 2 2012, 18:14:34 ------------------------------------------------------------ AFTER JTAG *** LOCKED *** PYRAMID PVT SHIP S-OFF RL HBOOT-1.27.0000 eMMC-boot Jan 13 2012, 17:33:34 ------------------------------------------------------------ and no radio version at all when i try these commands via fastboot here is what it gives (bootloader) version-baseband: N/A (bootloader) version-cpld: None (bootloader) version-microp: None i think that flashing radio via JTAG will do the job how to do that ? ThanX |
07-16-2013, 18:19 | #4 (permalink) |
Freak Poster Join Date: Apr 2003 Location: TURKEY Age: 48
Member: 25845 Status: Offline Thanks Meter: 26 | specter ...connect riff your xe .push resurrect button .now CİD TİCK ONLY and fill 111111111. after resurrection load any xe rom.. your radio back online..enjoy.. |
07-16-2013, 18:45 | #5 (permalink) | |
Member: 1477270 Status: Offline Sonork: specter16 Thanks Meter: 1 | Quote:
my phone was working normally one day i tried to flash RADIO or FIRMWARE (i forgot exactlly) i ended with phone stuck on bootloader with the following settings *** LOCKED *** PYRAMID PVT SHIP S-OFF RL HBOOT-1.29.0000 eMMC-boot Mar 2 2012, 18:14:34 and these are a detailed information with the fastboot getvar all commande i highlighted some strange information that i found (bootloader) version: 0.5 (bootloader) version-bootloader: 1.29.0000 (bootloader) version-baseband: N/A (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 9.99.999.999 (bootloader) serialno: (removed by me because it's not important) (bootloader) imei: (removed by me because it's not important) (bootloader) product: pyramid (bootloader) platform: HBOOT-8260 (bootloader) modelid: PG58***** (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3831mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 705f86f6 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.509s the phone with this state, i can't flash anything i get Fail-PU error i have no recovery installed and i can not go to ruu and i can not run moste fastboot commands nothing just the phone boots only to hboot (when i try to power the phone on, it takes loong time to power on after that it stays into hboot) some user experienced told me that i must JTAG my phone, so i JTAGED it and now here is the resault after the JTAG stage hboot displays this: *** LOCKED *** PYRAMID PVT SHIP S-OFF RL HBOOT-1.27.0000 eMMC-boot Jan 13 2012, 17:33:34 and fastboot getvar all command gives this green lines are the changes that i noticed after the JTAG stage red lines are strange lines that i don't know (bootloader) version: 0.5 (bootloader) version-bootloader: 1.27.0000 (bootloader) version-baseband: N/A (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.45.401.3 (bootloader) serialno: (deleted by me) (bootloader) imei: (deleted by me) (bootloader) product: pyramid (bootloader) platform: HBOOT-8260 (bootloader) modelid: PG5813000 (bootloader) cidnum: HTC__032 (bootloader) battery-status: low (bootloader) battery-voltage: 3555mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 617f0a98 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.509s and now i tried to flash a 3.33 universal firmware and i got the same error that i had before the JTAG stage ( Fail-PU) now i don't have any idea what can i do ??? | |
07-17-2013, 07:53 | #6 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi "Fail-PU" Usually Come From CPU Fatul..(Also usually Phone is hot when power on) Also I Think Maybe You Can See "XA" in Bootloader...Like This: Quote:
-- Then,Your Phone is "XE" But I see in last log you did use normal dll Because your Model ID is PG581300 but XE MID is "PG5813001 | |
07-20-2013, 19:18 | #7 (permalink) | |
no it's not my case and i don't think it's a cpu problem because before flashing the radio/firmware the phone was working super fine after flashing radio/firmware the phone gives these resaults | |
07-23-2013, 08:01 | #8 (permalink) |
Member: 1477270 Status: Offline Sonork: specter16 Thanks Meter: 1 | okay lets ask an other question can i use htc sensation full backup to my htc sensation xe of not, then where i can find htc sensation xe full backup i didn't find any in riff servers anf on the net !!! |
