12-19-2013, 15:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | How to sofa this problem samsung i8190 Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Connecting to the dead body...OK WARNING: Connection via USB failed with Code: 0xC000FF01 Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 18 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000035 ERROR: No Resurrection Data is available for the eMMC Chip with Capacity = 0B |
12-20-2013, 03:02 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi For First,18MHZ not so good idea.... Then,...if you sure about correct soldered wires and not shorting some wires to other ,it's HW problem.in fact eMMC chip What is phone history? Thanks |
