03-20-2013, 17:59 | #1 (permalink) |
Insane Poster Join Date: Feb 2012
Member: 1720473 Status: Offline Thanks Meter: 2 | How to unlock desire x Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4798.9590] Connecting to the dead body... ERROR: Set I/O Voltage to 2.60V failed. Real reading is 3.19V Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4798.9590] Connecting to the dead body... ERROR: Set I/O Voltage to 2.60V failed. Real reading is 3.17V Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4798.9590] Connecting to the dead body... ERROR: Set I/O Voltage to 2.60V failed. Real reading is 3.31V |
03-20-2013, 19:29 | #2 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Kz Age: 58
Member: 93002 Status: Offline Sonork: 100.1617660 Thanks Meter: 19 | Quote:
and .... what about history of yours phone? | |
03-21-2013, 09:18 | #4 (permalink) |
Member: 1720473 Status: Offline Thanks Meter: 2 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC ChaCha (PH0611000) V1.0.4745.47461] Connecting to the dead body...OK Detected dead body ID: 0x503C10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x66BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! box is 100% ok CHA CHA IN MINUT FINISH |
03-21-2013, 13:13 | #5 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, As for Desire X, from log we can see that You somehow connected some point where is 3.3V, and it's not part of JTAG port. You probably shorted something there, so simply carefully recheck everything. |
01-29-2014, 19:52 | #6 (permalink) |
Freak Poster Join Date: Dec 2009 Location: egypt
Member: 1188874 Status: Offline Sonork: 100.1610116 Thanks Meter: 8 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4841.63397] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000048 ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
02-08-2014, 12:17 | #7 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Quote:
I have same problem. I unlockd many desire x by riff but this is second phone wich NOT COMUNICATE with them. I check wires, solders... all is ok.. Phone stars ok,, riff is OK.... BUT I HAVE BAD LUCK Mihnea | |
03-31-2014, 20:06 | #9 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | i have same problem. Everything checked and it ha perfect connection. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4841.63397] Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 3,14V No error in connection, already tried 2 different cables, that works with other phones. |
03-31-2014, 20:27 | #10 (permalink) | |
Member: 1671934 Status: Offline Thanks Meter: 247 | Quote:
07-03-2014, 11:05 | #11 (permalink) |
Freak Poster Join Date: Dec 2003 Location: romania Age: 47
Member: 45811 Status: Offline Thanks Meter: 5 | Error in connected,look this! [START OPERATION_ID = RESURRECT] Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC Desire X (PM6610000) V1.0.4841.63397] Connecting to the dead body...OK Detected dead body ID: 0x007700E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (HYNIX, 0x0000E7000000 Bytes = 3.61 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (HYNIX, 0x000000200000 Bytes = 2.00 MB) Unlocking the Phone...OK Unlock complete! [FINISH OPERATION_ID = RESURRECT] |
08-13-2014, 11:54 | #12 (permalink) | |
Junior Member Join Date: Jun 2012
Member: 1778462 Status: Offline Thanks Meter: 0 | Quote:
