08-05-2013, 07:21 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | ht wildfire s t mobile restart when ressurestion ... Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. me instal same rom but same restart after htc logo . fone s-off cid super guide me plz where is problem |
08-05-2013, 08:23 | #2 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. after jtag tck speed chang show speed 4 mhz |
08-05-2013, 08:31 | #3 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | but my model not PG7610000 my model PG76240 and riff show Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 0.90.0000 (for NAND chips with 4Kb page size) and to 1.03.0000 (for NAND chips with 2Kb page size) versions. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PG7610000’. Additionally, you can check ‘Repair RECOVERY zones’ to reflash android BOOT and RECOVERY code. it means unsupported this model clear |
08-05-2013, 08:44 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
08-05-2013, 14:01 | #8 (permalink) | |
here i done with out any problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [HTC WildfireS V1.0.4522.55486] Connecting to the dead body...OK Detected dead body ID: 0x203C10E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00AD/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! maybe this will help u | |
08-05-2013, 15:19 | #10 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | job done but problem same restart here job done but ????????????????? after this me instal rom RUU_Marvel_TMOUS_1.62.531.3_Radio_47.10f.35.3032_7 .48.36.17M_release_202047_signed.exe |
08-05-2013, 15:33 | #12 (permalink) |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | u r good man selftest start result its botton not short ok if u not mind share me latest rom link i m waiting u r next reply u r real man RUU_Marvel_TMOUS_1.62.531.3_Radio_47.10f.35.3032_7 .48.36.17M_release_202047_signed.exe RUU_Marvel_HTC_Asia_WWE_1.35.707.3_Radio_47.10_.35 .3029H_7.46.35.08_release_188906_signed_2.exe RUU_Marvel_TMO_UK_1.34.110.3_Radio_47.10.35.3029H_ 7.46.35.08_release_189003_signed.exe already try but same |
08-06-2013, 00:24 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi After Resurrect Your Phone Convert to WWE by Rewriting MID,So You need Flash Any RUU Based on WWE,Also Please Install Latest Update Like Any RUU With 2.xx.xxx.x Also if you have restart problem at first stage,but have same result after resurrect+RUU May you need check HW .... |
08-06-2013, 06:59 | #14 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Quote:
08-06-2013, 15:08 | #15 (permalink) | |
Index of ./files/Wildfire S(Marvel)/rom/original/EXE/ | |
